Windows 7: Need help USB 2.0 to vga dual monitor connection
12 Jun 2013   #1
mcrump
Windows 7 home premium 64 bit
Okay I was told connecting the USB 2.0 to vga cable to my monitor and laptop would be easy but it has not.
I have an LG Flatron E1942 monitor with a vga/dsub port in the back. My laptop is an xps L502X with2 USB ports and an hdmi port.
I have a USB 2.0 to vga cable from cables to go.
Issue: I installed the drivers all fine but once my computer restarted the monitor remained black OR both monitor and computer remained black OR only my background image would display on my laptop (I've rebooted countless times). When the monitor is the only one black I can still move the cursor over to it but that is all I get.
I am so frustrated. Could anyone help me please?
FYI I tried an hdmi to vga cable once and nothing worked there either.
12 Jun 2013   #2
alphanumeric
Windows 10 Education 64 bit
Did you extend your desktop across to the second monitor? Press the Windows key and the P key then select Extend. Do you have a link for the USB 2 to VGA cable? It sounds like that is an external USB 2.0 video card.
12 Jun 2013   #3
mcrump
I have extended it and nothing happened...both are black screens right now. Once I unplug the cable my laptop goes back to normal.
12 Jun 2013   #4
mcrump
I should add its an adapter not a cable
12 Jun 2013   #5
alphanumeric
OK, its letting you extend so Windows is seeing the adapter and monitor but other than that I'm not sure what's going on. Anything in device manager with a yellow ! and does that adapter show up there correctly identified?
12 Jun 2013   #6
mcrump
There is no ! And it is showing up on the list correctly
12 Jun 2013   #7
alphanumeric
OK, Hmm, Were there any utilities/programs installed for it with the drivers? If yes have you run them?
12 Jun 2013   #8
mcrump
It's a plug it in and the drivers automatically download adapter
13 Jun 2013   #9
alphanumeric
Have you tried that adapter on another PC? Maybe its defective? Does it have its own power pack, maybe its not getting enough power from the USB port to run? That can happen on some laptops if the USB port doesn't supply the full 500ma.
13 Jun 2013   #10
mcrump
I was snooping around and changed the bit colour and now it's working fine thus far
thanks for helping me alphanumeric. I appreciate it.
Radeon HD 6670 Dual Monitor setup not detecting 2nd monitor
Hello I basically need conformation that I'll need to buy a new monitor in order to have a dual monitor set up with my current system. I'm not super tech savvy so if you need any other info please let me know. I have a Radeon HD 6670 with 3 ports, an HMID, VGA (which is my monitors type) and...
Graphic Cards
Dual monitor setup - fullscreen goes on wrong monitor
First of all, hello! And thanks for your time! I am running a dual monitor setup with my TV hooked up via HDMI to my laptop. Everything was working fine before, I always had the laptop as my main display yet I could play a video or a game fullscreen on the TV. Since a couple of days, as...
Graphic Cards
I am having troubles getting my dual monitors back. Initially had a GeForce 8400GS 512MB PCI video card and was using the on board video (Biostar G41 M7 MB) for dual VGA monitor setup. I've installed a Radeon HD 6670 1GB PCI-E video card with monitor one setup via DVI to VGA adapter on output...
Graphic Cards
Setting dual connection - monitor+tv
Hi, I would like to keep my win7 system connected simultenously both to a tv set and a monitor. My tv is connected via hdmi to a Lg tv set and my monitor is a Samsung syncMaster 940bw. My problem is htat when the pc is connected to the tv set, my complete win7 session, from the BIOS related Post...
Graphic Cards
Dual monitor issue, secondary monitor is undetectable
I have just did a clean install of Windows 7 ultimate from XP and I am unable to get my dual monitors to work like they did in XP. I have a DVI Radeon graphics card plugged into the agp slot, and a Nvidia geforce vga adapter plugged into a pci slot of my dell optiplex 755. When I am in the...
Graphic Cards
dual monitor problem (primary monitor disappears)
I've searched some forums and while i have found all sorts of dual monitor problems i haven't found this one. I have a MSI M670 laptop ( with nvidia 6100Go graphics card ) and a Samsung SyncMaster T240HD. I always connected my monitor with a VGA cable on my windows xp and everything worked fine....
Hardware & Devices
İ Designer Media Ltd
