Windows 7: Spontaneous restarts, perhaps seemingly caused by power switch? Help!
06 Aug 2013   #11
450125
Win7 Professional 64
Marking as solved. I finally brought the computer to a shop to look at. They loaded some "stressful" program onto it, and in 20 minutes the computer rebooted. Put a new 400 watt power supply in, and the computer has performed perfectly since that time at least 2-3 weeks ago.
07 Aug 2013   #12
Layback Bear
Windows 7 Pro. 64/SP-1
I glad you are fixed and thank you for letting us know how you solved your problem.
BSOD seemingly at random, possibly Chrome caused
My PC keeps blue screening with seemingly no cause, every time it's a different reason as to why it crashed, so I'm thinking it's hardware, my PC is fully up to date and nothing, as far as I can think, has changed lately to cause it to happen. I hope someone can help me out, it appears so random...
BSOD Help and Support
BSOD and spontaneous restarts (No known recurring event found)
Hello all, I will provide as many details as I can since the thread title is a bit ambiguous. I'm having a problem with my parents computer that I can't seem to pin down. Attached is the latest dump file from a BSOD. However, the machine will also spontaneously restart on its own, most often...
Kernel Power - Event ID 41 - Task Category 63 (spontaneous improper sh
BSOD happen only recently...
(Seemingly) random BSOD crashes and restarts
Starting this morning I heard my computer restarting itself over and over, it would get to where it says "Starting Windows" except the background was black with what looks like colons and periods all over in rows, and then it would blue screen and restart. I could load into safe mode and do...
BSDO Caused at Seemingly Random Moment (DRIVER_IRQL_NOT_LESS_OR_EQUAL)
- Acer Aspire 6920G - Installed: Windows 7 Ultimate x64 - Full Retail Version (Original OS: Windows Vista (deleted)) - Age of System: approximately 3 years (bought used) - Age of OS Installation: approximately 4 months
New PC, 2 BSODs since yesterday seemingly caused by the GPU.
Yesterday I built a new PC and I've already had two BSODs, one while playing Tribes and the other while simply sending an email. After the first BSOD I removed the beta driver I was using (with Driver Sweeper) and reinstalled the official driver and it seemed to fix some issues I was having,...
