Windows 7: Hard drive cable not sure if it needs replacing
20 Jul 2013   #1
Summerbear5
I have an HP windows 7 64bit Fully updated via windows update.
Over the years I have slowly upgraded parts inside here and there.
One of the things I upgraded was the harddrive from 750gb to 1TB...The old one went out had bad sectors.
Everything has been working fine for years and years...recently I took some canned air and blew out the dust from inside of the computer while in conjunction holding the vacuum hose to suck up the dust. After doing that I had a couple problems with the harddrive not sure if it's going out again, the motherboard is acting up, or if the harddrive cable just needs to be replaced.
I'm pretty sure it's the harddrive cable and I can pick up another one for $6 but I wanna make sure positively before I go out and buy it.
The first thing that happened was the whole computer locked up and nothing was working not even ctrl+alt+delete. I manually turned off the computer and turned it back on. After turning it back on it was just a black screen nothing happened, I was able to table F9 and go into diagnosis and it said "boot path test, BIOHD-5" test failed.
I then restarted the computer and it said to turn off computer immediately and replace harddrive (I was in a panic) I then opened up the computer and checked all cables and connections. Completely took out the harddrive made sure there was no dust plugged it all back in. Turned the computer back on and everything was working fine, back to normal.
This morning the same thing happened, I turned the computer on started using it and again the whole computer locked up. I manually turned off the computer restarted and it said disk error ctrl+alt+delete to restart. So I again I opened the computer and checked all cables, unplugged and plugging them back in. Closed up the computer and boom started working perfectly again.
So after all is said and done what is the problem? Is the cable just old and needs replacing or the harddrive going out? Or maybe the motherboard?
Thanks for reading,
Summer
20 Jul 2013   #2
Layback Bear
Windows 7 Pro. 64/SP-1
It would be very difficult to wear out a cable. You could check and see if the cable has been rubbing on something causing damage. If in doubt just replace the cable.
About the only way a mortal human can test a motherboard is visual inspection or replacing it. The manufacture and/or a computer laboratory could test it.
If it was my computer after inspecting or replacing the cable I would test the hard drive with the manufactures drive test.
Another option would be.
Disk Check
20 Jul 2013   #3
Summerbear5
I might go ahead and replace the cable. It's just so weird because even if it was a lose cable problem after I fixed it the first time it's strange how it happened the second time even though I didn't disturb it. The cable is short and bent over to connect at both sections.
In general knowledge though would a failing motherboard cause a problem with the harddrive as it is?
20 Jul 2013   #4
Layback Bear
Any time you plug a cable into a computer component and it is in a strain from a sharp angle you could have poor connection. After the connection is made their should be no (zero) side pressure on the connection.
Could a motherboard cause this kind of problem; sure it can if the female connections on the motherboard has been damaged. This type of damage is normally visible and cause by not plugging cables into it properly.
I still recommend testing your hard drive first. It cost nothing but a little time. If in doubt just replace the cable. They are cheep.
Never assume their is only one problem.
20 Jul 2013   #5
bobafetthotmail
Win 7 Pro 64-bit 7601
The surest sign of a failing cable is CRC errors. Grab HD tune or whatever hard drive checking software and have a look at how much CRC errors there are, and if they are increasing with time.
Will also tell us how is the HDD.
I'm also suspecting the PSU. The PSU is always a suspect when there are hardware errors of some kind.
Can you check from the BIOS what are the voltages and what are the voltages when running with HW Monitor?
20 Jul 2013   #6
Summerbear5
All harddrive checks that I have done so far came up as everything is ok. That is when it truly is booting up properly and it's ok, so it seems.
Bob please tell me how to do what you suggested. Thank you.
20 Jul 2013   #7
DocBrown
I assume your HD is a Sata with a small Sata data cable
Not an IDE flat ribbon cable.
Also as mentioned above, the computer PSU. How old is it ? What brand is it ? How many watts is it rated for ?
Since you have had to power OFF the computer several times you may have some corrupted files. Maybe run System File Checker to replace any missing or corrupted files.
21 Jul 2013   #8
bobafetthotmail
Quote   Quote: Originally Posted by Summerbear5 View Post
Download DiskCheckup, and run it (no installation required) select your hard drive and go in the tab called SMART info, scroll down and read the raw value field of "UltraDMA CRC error count".
If there is any field not tagged as OK in the status, please report it.
Write it down. After a few days of use run it again and see if the number has increased. If it has increased, the cable is either damaged or bent in a bad way. SATA cables hate being bent, must do only smooth curves. Does not damage them, but the performance will suffer.
Also do what DocBrown said.
21 Jul 2013   #9
Summerbear5
Yes DocBrown it is Sata...I will post the other information when I can. Thank you.
EDIT: I already ran check disk and everything was fine. There was two things that it removed and then recovered but other than they everything was fine. I will still download what you provided and use that too.
21 Jul 2013   #10
Summerbear5
Quote   Quote: Originally Posted by DocBrown View Post
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
Replacing hard drive and installing W7
I use a trayless hot swap rack. I have dear old XP3 on one drive which I swap for one with W7. The W7 hard drive is showing its age and so I have bought another drive. I still have my original W7 installation pack together with the product key. My desktop is to stay the same apart from my probably...
Installation & Setup
replacing a hard drive
I am looking to replace my hard drive with a ssd.I have a acer aspire all-in one z5610 I am doing research on what/which ssd is best ? which will fit my system? what size is best 256? I have looked at crucial and kingston the all-in-one is very similar to a laptop(no spare bays) I would...
Hardware & Devices
Replacing Hard Drive - What do I need to do prior?
Hello, I am going to replace my hard drive and want to install an OEM Windows 7 O.S. The current hard drive is about 250 GB. I would like to install a 1TB hard drive as the primary drive, then use the other drive as a second hard drive. Can I do that? Where do I go to set this up? When...
Hardware & Devices
I get a BSOD, despite replacing the hard drive
I'm at my wit's end here. So I've had a computer now, for about two years. I use it to do schoolwork, play tf2, post on a forum, nothing major. But I swear, it's like whatever I use with the computer only has a short amount of life before failing. I got the computer from a more savvy friend....
BSOD Help and Support
Replacing hard drive and restoring everything
I have a 4 month old HP laptop whose hd is failing. The good news: they are sending me a new hd. The bad news, it is a blank hard drive. So I need to restore everything on it, including the system. Time is of the essence because I have 3 days after it arrives to return the defective drive to HP...
Help. Replacing Laptop Hard Drive
I'm getting a bigger hard drive for christmas and i'm unsure how I'm going to go about cloning my current hard drive and putting it onto the new one. First question; what program do I use to clone my Win 7 OS to the new Bigger hard drive? Second question; when cloning the hardrive do I copy...
Hardware & Devices
