Windows 7: Buying Recommendation for Color Multifunction Wireless Laser Printer
28 Jul 2013   #1
mavigozler
Windows 7 Home Premium 64-bit
I am getting a color multifunction wireless laser printer primarily for a soon-to-be university student, although I am told submitted coursework is now paperless. I am not sure. Still, I might need one for resumes and job applications.
  • One that is the most economical on consumables, that is, toner: spend more on the printer, less on the consumables, right?
  • Color: I can do the screen-to-paper color calibration, if necessary
  • Multifunction: only really need the scanner, not so much the copier (which can be done by scanning and printing, right?) or the fax (21st century and all....maybe I should get JUST the printer, and buy a cheap scanner separately?
  • wireless: and it's probably not convenient to connect a Cat 5 UTP cable to a wireless router
  • if I am going to have the scanner, ought to have the document feeder...it's really convenient
  • small footprint and not needing a crane to lift it would be nice too
  • doesn't need its own display...after all, it can be controlled through the desktop/laptop
  • speed not a factor
13 Aug 2013   #2
mavigozler
Replying to my own post:
I found a Consumer Reports 2013 Buying Guide, and in the section on printers, they said to stay away from color lasers...that they were not ready for prime time.
So I went with a color inkjet.
Stay intellectually curious, my friends.
Brother Wireless Laser Printer - Installed, connected but cannot print
I set up the printer (HL-2270DW) following all instructions. It is listed under Devices and Printers with my other printers, but not under Printers. I cannot set it as default printer in Devices and Printers. When I go to printers -> add new printer -> wireless printer it is found, but it says...
Hardware & Devices
Brother color laser printer not supporting Win 7?
I have not unpacked my multifunction MFC-9330CDW, because I had ordered 9340. But carton says: OS version, Win 7, supported functions Print Scan PC Fax (black & white only) Does the "black & white only" refer only to "PC fax"? Anyone knows?
Hardware & Devices
Multifunction laser printer suggestions
Hi everyone, I am looking to buy an all-in-one colour laser printer. Haven't had one before, so I'm hoping for suggestions?? - Looking to spend around 3 - 400 GBP. - Would like seperate CMYK toners, rather than just black and 'colour' - Also something that has good availability of...
Hardware & Devices
OKI MC561 Multifunction Printer help
I have just purchased the above but the installation has been far more complex than I expected. Installed from CD using USB connection. There was one error that seemed to come from Windows 7 Pro rather than the install program which stated that PCL had not been installed successfully. Not sure...
Hardware & Devices
Manually add a network multifunction printer?
Hi, I have a Windows 7 Ultimate 64-bit PC connected to a home network with other PCs connected. Additionally, there's a network printer (HP Officejet 6310xi) that available on the network. Now when I had my XP PC on the network, I was able to access the printer's printing, scanning and faxing...
Hardware & Devices
HP PSC1200 multifunction printer/scanner
The XP driver for this was pretty good for a typical cumbersome driver from HP. The Vista/W7 driver works minimally and the control panels look great but: 1. Normal vs. Fastdraft print selection results in terrible low density quality. 2. Can't change the default printer selection.
Drivers
