Windows 7: Problem with USB speed
10 Aug 2013   #1
andrew129260
Windows 10 Pro
Hi everyone. I am having a major issue with slow USB speeds (1.30MB/second usb 3.0). I thought I had solved it but apparently not. Slow speeds occur on every USB port.
I have attached a screenshot of my device manger and the usb ports that are no my system.
Note: I have no hubs or anything installed like that. All usb ports are built in on motherboard except my four front ports on my case, that is directly connected to usb 3.0 adapter on the motherboard.
*Yes there are a mix of usb3.0 and usb 2.0 sorry.*
Anyways, this is what I have done:
1.) Selected better performance for flash drives and my external hard drive.
2.) Disabled usb selective suspend. Set power options to performance before that.
3.) Uninstalled ALL (including hidden devices ones) usb devices.
4.) Made sure bios is up to date - it is. Made sure settings for usb devices was all enabled and set to fastest setting.
5.) Reinstalled Windows 7 pro sp1 x64
6.) Have all windows updates and optional.
7.) USB drivers are up to date for both times before reinstall and after.
8.) I have tried disabling my avast antivirus when copying files, still no luck.
9.) Under device manager I have checked power management tab for ALL usb devices and disabled it from turning off the device to save power...
Anyone have any ideas? I am out of them....
PS Thanks again.
10 Aug 2013   #2
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
hey andrew you aren't showing any indicator of USB 3.0 spec there.
All the USB ports on a PC are likely not ALL 3.0's, mine, albeit a 2 year old motherboard, has only 2 actual USB 3.0 ports, and if you don't use a USB 3.0 hub or what's call a SPEED cable for USB compatibility, you'd have to directly connect the USB 3.0 devices to those specific ports otherwise it's likely 2.0 or worse 1.x.
Plus of course the drives themselves need to be USB 3.0
Motherboard handling of USB varies, I had to install a specific driver, I have attached my device manager listing.
I bought more expensive ($22) hubs and speed (USB 3.0 spec) extension cable to get what I needed done.
I only have some external HD's that are USB 3.0's.
That clear anything up for you? [drivers for motherboard USB 3.0 controller is what I would be looking for]
10 Aug 2013   #3
andrew129260
Windows 10 Pro
Sorry yes, I have updated original post. I have 6 usb 3.0 and 10 usb 2.0. Two usb 2.0 on front and 2usb 3.0 on front.
The asmedia in device manager there are my usb 3.0 drivers. That's what it was called when i installed it from the motherboard cd. The cd said it was the drivers for my usb 3.0 ports. I didn't find any updates drivers on Asus website.
My other concern is maybe I have to many usb devices connected. My room is in the attic that was turned into a bedroom.
I have the following usb devices connected:
-A usb wireless adapter
-wireless mouse
-usb wired keyboard with 2 usb ports built in
-monitor with webcam and 2 usb ports built in that connects to my computer by usb.
With all those usb devices maybe they are competing with bandwidth? I don't use the usb ports on the keyboard or the monitor, so I could disable them if that would help. Trouble is I do not know if I could disabled the ports on the units themselves without disabling the port its on. As I need the webcam and keyboard to function.
Okay, I also forgot to mention I have tried disabling my avast antivirus when copying files, still no luck.
Hope that all makes sense.
10 Aug 2013   #4
Faladu
That F: drive, what is it?
USB itself can handle a lot of devices (over 100), if it draws a lot of juice a USB device comes with it's own power source.
Fragmented files could slow you down, you did do thousands of files at once.
10 Aug 2013   #5
andrew129260
Windows 10 Pro
F drive is my Flash drive. I also want to add/point out when i plug ether my flash drive or external hard drive to another computer, the transfer rate is fantastic. Around 18MB/s
(Same music folder by the way.)
But my computer its slow...
By the way, disk defrag says it is not needed. 0% fragmented.
Thanks for your help again
12 Aug 2013   #6
andrew129260
Windows 10 Pro
I have ran out of ideas as to why this is happening...I just restarted and plugged my flash drive in. I started copying things off it to my computer. That was faster than before. 11MB /s
But then when I went to copy things to it, it was 3MB /s
I then tried using my external hard drive and that produced the same slow results. IT's like the speed gets slower the longer my computer is on. So weird....
And its fast 18MB/s when I plug into into another computer, even one that has been on for awhile..
I am transferring the same content (Music) so it does not result in different results.
19 Aug 2013   #7
andrew129260
Windows 10 Pro
Any more Ideas? Thanks everyone.
19 Aug 2013   #8
Boozad
USB 3.0 has given me headaches on both of the rigs I bought this year, mainly from the USB 3.0 header at midboard. One was an ASMedia XHCI such as yours and my latest one is an Intel 8 Series EHCI. Granted I'm getting 10Mbps on my front ports on the Intel controller but it still throws up problems left right and centre.
20 Aug 2013   #9
andrew129260
Windows 10 Pro
Thanks for the reply. Yeah, I have no idea what is going on here. I have kinda given up. Don't know what else to do. I guess I'll just live with it. Maybe my motherboard mftr. ASUS will release a update for the board for speed issues with usb. Maybe I'll get lucky
I would call them about it, but I probably will be told the same things I have already done.
I do feel like its an issue with usb bandwith. But I like my keyboard and monitor. Just wish there was a way to prevent windows from seeing the usb ports on them that I don't ever want to use.
20 Aug 2013   #10
Boozad
Quote   Quote: Originally Posted by andrew129260 View Post
I'm not sure to be honest, all I have connected to my rig via USB is a keyboard, mouse and printer (which is hardly ever used) which are all USB 2.0, and a Hitachi Touro external HDD which is USB 3.0. Whenever I connect my Kingston Data Travellers to my front USB 3.0 ports I get the 'This device can perform faster when connected to a super speed USB 3.0 port'. I've reinstalled drivers over and over again but nothing seems to fix it, my rear ports all work fine so it's definitely something to do with the mid board headers.
USB 3.0 HUB speed problem
I just purchased a Ultra Aluminous 4 port USB 3.0 Hub. My computer has been relocated and it is now very difficult to get at my 3.0 ports on the back of the machine so I thought this would make life easy.:sarc: My latest Renesas USB 3.0 driver software sees the new hub as USB 2.0 and installs...
Drivers
Internet Speed Problem
Over the last 3 or 4 days my wireless connection has started becoming very slow and oddly it uploads faster than it downloads at th moment. I have tried scanning with MBAM which reports its clean and I have laso used SuperAntiSPyware which cleaned a couple of items and now says that it's clean....
Network & Sharing
Internet speed problem
My internet speed is 256 kbs (download) when i go to speedtest it shows that my speed is 1.8 mb/s My ISP sais that it should be 2048kb/s But its never over 250kb/s NEED HELP!!:cry: Its a ADSL(broadband)connection with modem: Paradigm PTI-8411 Annex A (its from ISP) and TP-Link wireles...
Network & Sharing
Odd speed problem behind a router
This is from my last post moving to the next confusing problem. My customer has 4 computers hooked up to his router. The customer recently got his line repaired and is hooked right up to his node directly outside his house. Going right to his modem he gets 60mb. Once he hooks up to his router...
Network & Sharing
Speed problem
Hey there I'm subscribed to 8mb/s connection. There's no connectivity issue, no disconnects but the porblem is speed. My few YouTube videos buffer, downloading speed normally from sites is 200-300 kb/s. Only few sites like Ubuntu, Microsoft sometimes gives me full speed. Is there any problem with...
Network & Sharing
download speed problem w/ openDNS
i noticed a problem on my download speed. when i tried using openDNS a few hours ago, i noticed that my download speed goes up and down. my max DL speed is 700kB/s. but when i used openDNS, it goes down to about 1/2 to 3/4 in speed when im browsing the internet w/c does not happen before i use...
Network & Sharing
