Windows 7: Blank CD/DVD read problem - Possible solution.
12 Aug 2013   #1
ViperMWC
Windows 7 Home Premium 64 bit - SP1
Hello all,
I've been wrestling with this problem a while now, and have tried pretty near all the hints and tips on the Forum to no avail.
Having lost one or two DVD's formatting them via the open Explorer folder method and choosing the
'Live File System' or 'Mastered', only to find the DVD un-useable as it's already FULL, ie no free space.
Got to thinking about that, and realised you don't really FORMAT a DVD the way you do a hard drive,
you burn files to it. So I had a look and thought, where is the BURN option on my Windows Explorer
ribbon bar ?
This is what you should see - Mine was missing....
[See attachment - Ribbon Bar 01]
Off to the big Google in the sky to look into this, and found an article showing how to REMOVE the BURN option, so I thought, well if you can remove it, you can put it back.
This is the article, hope the mods don't mind me showing something from another Forum.
How to Remove “Burn” Button from Windows Explorer Command Bar in Windows 7? - Tweaking with Vishal
If you read through it, things are quite straight forward, even though it is a REGISTRY poke about, so
make sure you BACKUP the registry first.
Assuming most of you have either the Home Basic or Home Premium versions of Windows 7, the 2nd part of the article is more relevant.
Following the instructions as if I was going to REMOVE the BURN button, I was surprised to find I had the DWORD 'NoCDBurning' already in my registry !! [How it got there I have no idea] I took the simple step of deleting the whole DWORD entry !!
After a re-boot the results were -
First DVD I put into my drive, up pops the expected FORMAT choice dialogue box.
Step one passed ok.
Dragged a few files and odds and ends to the DVD
The vital thing here is the "Close Session" button appearing.
[See attatchment Ribbon Bar 02]
This closes down the burn operation so you can add more files at a later time to the DVD
Step two passed ok.
[I have added files to the same DVD four different times now so things are working ok.]
I'm not sure if this will work for you, but it's worth checking out that DWORD entry and finding out
what the setting is on your machine.
All the best,
Mick C.
P.S. I've been using DVD-R/CD-R and CD-RW for this testing.
Blank CD/DVD read problem - Possible solution.-ribbon-bar-01.jpg   Blank CD/DVD read problem - Possible solution.-ribbon-bar-02.jpg
12 Aug 2013   #2
fireberd
One word of caution, UDF formatted discs (RW) have a history of losing format and/or data. This goes back many years and includes Nero InCD, Roxio Drag to disc, etc. It would appear these discs can be used like the old floppies and to add, remove data, reformat, use again, etc. But its an iffy proposition. Best suggestion, if you want to use UDF, do not have your only copy of any data on one of these.
My take is if I want to put it on a disc, I use an "R" disc only. Discs are now relatively cheap so 10 or 15 cents (US) for something to save data to is insignificant. The other option is to use a flash drive instead of an RW disc, you can then read, write, rewrite, etc.
I also use a regular burning program (I have the full Nero suite that I use in my recording studio). The free and popular Imgburn and CDBurnerXP are other options.
12 Aug 2013   #3
ViperMWC
Hi fireberd, good points. For me it's a temporary measure anyway. External drives for long term stuff.
The point of the post was the failed recognition of ANY blank media. No idea why my system went like that, but this "solution" worked for me.
Mick C.
Why won't my DVD RW drive (D) read blank discs?
This just started happening recently and I don't know why. I am using the same discs that have worked before and everything looks good in device manager. It tells me my driver is up to date and working properly. It will read older discs that I've put files on but when I try to make a DVD it just...
General Discussion
CDDVD Suddenly Won't Read Blank Media
Acer Aspire 4530 W7-64 Ultimate internal TSST Corp TS-L633A A00 CD/DVD writer. This driver/burner had been working fine, reading blank media and burning audio CDs. Last time I burned CDs was 4mos ago. Burned about 5 at that time. I went to burn one the other day and the drive can no longer...
Hardware & Devices
DVD fails to read Blank DVDs and CDR
As the title said that is my problem. Before you answer, do not tell me the write head on the Optiarc 5600s is bad. It is not, It works fine in Linux. I need to find out why the DVD will not read blank discs. I unistalled Nero 10 and it rand fine then stopped working again. I installed Roxio 2011....
Hardware & Devices
Samsung DVD writer se-s084d cannot read blank dvd+r in Windows 7 x64
Hello All, I have two Lenovo s205 laptops both running Windows 7 Home Premium x64 and I have a Samsung DVD writer se-s084d (firmware is TS02). In one of the laptops the blank DVD+R disks are not recognised (from Sony and Verbatim) but it does recognise CDs and can play DVDs too. The...
Hardware & Devices
Possible solution for common SATA DVD won't read disc
I have been way behind the curve on doing upgrades to my computer. I was still using XP until last weekend. One thing that stopped me was for months now my DVD R had packed it in and would no longer read discs. I seldom needed the drive so ignored the issue and I never seemed to have the time to...
Hardware & Devices
Outlook icon has changed into blank page with box in middle, solution?
Hi all, As you can see in the photo my Microsoft Outlook icon has turned into a blank page with a box in the middle. How can I restore it to its original image?
Microsoft Office
