Windows 7: How to View 32bit Hard Drive on 64bit System
20 Sep 2013   #11
tinmar49
w7 ult 64 and w7 hp 64 X 2 mint 64 8.1 64 10wtp 64
Try downloading the free version of "mini tool partition wizard" it can often see a drive that Windows cannot.
32bit drivers for 64bit system work around
Hello, I have installed vista 32 bit on a partitioned drive of my vaio laptop which cam with windows 7 64 bit. I have numbed myself to some of the issues i have with seven, but i can not use it for my music (WMP12 stinks, library issues). I have vista up and running, but when the intel...
Drivers
How to View 32bit Hard Drive on 64bit System?
Hello This is CrazyKilla I am here with another porblem, I recently got a new custom pc, i have a 300Gb 32bit hard drive, stupid me forgot to save my files from the 32 bit hard drive, onto a usb, now i have a 64bit system, and a 64bit hard drive, i want to get my files back from the 32bit HD...
Hardware & Devices
Migrate system from 32bit to 64bit
I did ask a question about this some time ago and discovered that there was no easy way to do it (I'd thought to use Macrium Reflect). I recently saw that there is now a facility within Macrium Reflect - Redeploy - that reads as if it could be used. Does anyone know whether this would be...
Installation & Setup
Installing 32bit IE9 on a 64bit system
It has been said that the 32bit IE9 is a lot faster than it's 64bit sibling. But the installation of the 32bit version on a 64bit system is a bit confusing. This article helps. More...
Browsers & Mail
Operating 32bit programs on windows 7 64bit system
I went from windows XP to Windows 7 and have several program disc that I was using with Windows XP that I would like to install and use on my Windows 7. When I try to install them a small splash screen appears that says I am using a 64 bit system and this program will run on this computer. When...
General Discussion
How can i setup a software(for 32bit) in a 64bit system
HI, I have a 64bit win7 system, and I also have a sofeware that can work well in a 32 bit system, But it can not be setup in a 64 bit system,How can i make that work in my 64 bit system? I have update the windows to latest. Thanks very much.
