Windows 7: How to View 32bit Hard Drive on 64bit System
17 Sep 2013   #1
basils57
Windows 7 Home Premium 64bit.
I'm trying to check a HD that's might have 'died' with an external adapter, but the subject is 32 bit and the only machines available to me are 64 bit.
Any ideas please?
17 Sep 2013   #2
Bongo
Win 7 Pro x64 / Win 10 Pro
If you are using an external adapter it should be able to read the hard drive rather it was 32-bit or 64-bit OS on it.
Jerry
17 Sep 2013   #3
Anak
Win 7 Home Premium 64bit Ver 6.1.7600 Build 7601 - SP1
Would this approach help? Post #2: How to View 32bit Hard Drive on 64bit System?
17 Sep 2013   #4
basils57
Thanks for the response guys.
Jerry, when I switch the external adapter on, I have to wait about 5 mins. for a response, and then get a message saying that I need to format the disk before I can use it?
Also, I've just tried a different HD (32bit) and this reads OK.
Would you say the HD is shot?
17 Sep 2013   #5
Bongo
I am not a hardware expert so not sure, wait for others to reply.
Jerry
17 Sep 2013   #6
strollin
W10 Pro desktop, W10 laptop, W10 laptop, W10 Pro tablet (all 64-bit)
The files on a hard drive aren't 32 or 64 bit so the files should be able to be read regardless. If you were attempting to boot the drive with a 64-bit OS, then a 64-bit capable processor would be required.
My guess is that the hdd has failed. Have you tried connecting this drive to another PC? Another factor would be what filesystem the hdd has on it. Did it come from a Windows machine? If it came from a Linux or Mac machine, for instance, the file system will probably not be readable by a Windows machine.
17 Sep 2013   #7
Layback Bear
Windows 7 Pro. 64/SP-1
Hard drives are not 32 or 64 bit, only the information (data) that is on them are 32 or 64 bit.
According to your specs your system you should be able to use 32 or 64 bit data if the hard drive can be accessed.
Please post a full picture of your Disk Management.
Please use this to post the picture.
17 Sep 2013   #8
strollin
Layback - The data is neither 32-bit or 64-bit, the programs (and OS) on system are designed to handle data in 32-bit or 64-bit chunks but the data itself is in bytes, a byte is 8-bits. In theory, a 64-bit system could read the data 8 bytes at a time while a 32-bit system could only handle 4 bytes at a time. That's a very simplistic view but enough to hopefully explain that the data is neither 32 or 64 bit.
17 Sep 2013   #9
Layback Bear
I understand what you are saying strollin.
I didn't think getting more technical would help the OP.
I don't believe the physical hare drive has any control over 4 bit or 8 bit at a time just like it doesn't have control over a 32 or 64 bit data. The hard drive is dumb. If the hard drive is accessible and formated properly with a drive letter it should work with what ever bit data is sent to it or requested from it 4 bit or 8 bit looking at the OP Specs.
I think a picture of Disk Management would be helpful.
20 Sep 2013   #10
basils57
Hi again guys.
I finally couldn't get the HD to respond at all, so have replaced it with a new HD - albeit 500GB rather than the 1TB which failed, and have even managed to get Windows activated.
Thanks for your help and assistance.
32bit drivers for 64bit system work around
Hello, I have installed vista 32 bit on a partitioned drive of my vaio laptop which cam with windows 7 64 bit. I have numbed myself to some of the issues i have with seven, but i can not use it for my music (WMP12 stinks, library issues). I have vista up and running, but when the intel...
Drivers
Hello This is CrazyKilla I am here with another porblem, I recently got a new custom pc, i have a 300Gb 32bit hard drive, stupid me forgot to save my files from the 32 bit hard drive, onto a usb, now i have a 64bit system, and a 64bit hard drive, i want to get my files back from the 32bit HD...
Hardware & Devices
Migrate system from 32bit to 64bit
I did ask a question about this some time ago and discovered that there was no easy way to do it (I'd thought to use Macrium Reflect). I recently saw that there is now a facility within Macrium Reflect - Redeploy - that reads as if it could be used. Does anyone know whether this would be...
Installation & Setup
Installing 32bit IE9 on a 64bit system
It has been said that the 32bit IE9 is a lot faster than it's 64bit sibling. But the installation of the 32bit version on a 64bit system is a bit confusing. This article helps. More...
Browsers & Mail
Operating 32bit programs on windows 7 64bit system
I went from windows XP to Windows 7 and have several program disc that I was using with Windows XP that I would like to install and use on my Windows 7. When I try to install them a small splash screen appears that says I am using a 64 bit system and this program will run on this computer. When...
General Discussion
How can i setup a software(for 32bit) in a 64bit system
HI, I have a 64bit win7 system, and I also have a sofeware that can work well in a 32 bit system, But it can not be setup in a 64 bit system,How can i make that work in my 64 bit system? I have update the windows to latest. Thanks very much.
