i Have replaced and it still says plugged in but not charging
No probs mate I was just hoping maybe it was an older machine that could be fixed.
The problem though is very odd to say the least if the battery, mobo and adapator have been replaced then maybe the new mobo is no good??
I would really like to have it on the bench to check out the volts on the battery terminals with the battery out adaptor plugged in and the machine powered up just to see if there is any charge going through to the battery.
I suppose one way to try is the let the machine stand switched on and plugged in and then run the machine on battery alone and see how long it lasts. Maybe it is the reporting circuitry not functioning properly.
Hi munchlax11,
Its great to hear that you were able to replace the same. I understand it is not working at the moment as well.
Please let me know which battery and adapter you have purchased so we can check the specifications for the same and confirm if either one of them is not compatible to each other.
It could be an issue with the motherboard as well and you should try and return the motherboard for different one if it is still under free return policy.
Keep us posted with the results.
