Unable to xfer files from SD card to computer via built in slot
  1. Posts : 394
    Home Premium 64 bit
    I insert card but the relative drive does not open. However I can (I think as it worked last time) make the transfers via a standalone card reader and usb.
    Any idea what could be causing the problem? Please!
  2. Posts : 18,415
    windows 7 home 64bit
    Hi there ... Your Internal Card Reader does not recognize your SD card ? .. Are there any errors in the Device Manager ..
  3. Posts : 394
    Home Premium 64 bit
    Hi! I cannot see any!
  4. Posts : 18,415
    No errors .. So when you insert your SD Card it does not show up on your Computer? .. But it works on the External Card Reader ?
  5. Posts : 394
    Home Premium 64 bit
    Korrrect!
  6. Posts : 18,415
    Hi there ... What is the make and Model Number of your Computer ..
  7. Posts : 1,486
    Windows 10 Pro
    make sure that the "lock" on the card is not on.
  8. Posts : 394
    Home Premium 64 bit
    @ maxie Dell desktop 560MT
    @ N00berG00ber Card is in up (nearer to contacts) position.
  9. Posts : 18,415
    Hi there ... Go to the Device Manager click on View/Show Hidden Devices .. Then please post a screenshot ...
  10. Posts : 394
    Home Premium 64 bit
    Done and file attached!
    Attached Thumbnails Attached Thumbnails Unable to xfer files from SD card to computer via  built in slot-devman-extviiew.gif
