Windows 7: problem with my PC power supply
17 Oct 2013   #1
AIMAN SNK
windows 7 64bit gaming EDITION
my specs
mobo:P8B75-MLX
P8B75-M LX - Motherboards - ASUS
ram:8gb
graphics card:gtx 660 Twin Frozr 2gb
and my PSU:Cooler Master EX2 525watt
Cooler Master: Extreme 2 525
i just bought some 3 weeks
and now turn on my pc
and
no power or
damage
but my old psu 230watt works fine
or psu 525watt too much power for gtx 660
can cause damage
or my motherboard cannot handle
sorry for my bad english
17 Oct 2013   #2
linnemeyerhere
Windows 7 Ultimate 64
AIMAN SNK,
Welcome to SF and the answer to your questions is no, this PSU is likely bad but if it is or was performing well and connected properly then more power is never a danger as the components only draw the power they need.
17 Oct 2013   #3
Layback Bear
Windows 7 Pro. 64/SP-1
As linnemeyerhere has stated. You can't have to much power supply.
If you computer demands lets say 300W a 1000 W power supply will only put out 300W.
A quality power supply for your system I would recommend a Corsair or Seasonic in the 650W range.
Your video card requires a 500W or higher.
18 Oct 2013   #4
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
If you only bought it 3 weeks ago take it back to the store for a new one. If you built it, return the PSU.
Make sure all cables are connected and there is power coming from the wall outlet.
18 Oct 2013   #5
linnemeyerhere
Did you by accident flip the power switch on the PSU? Don't laugh it's happened to me.....
18 Oct 2013   #6
AIMAN SNK
Quote   Quote: Originally Posted by linnemeyerhere View Post
mmmm first time i bought i see is off
now switch to ON
but that is first i bought and after that i dont touch anymore
can I ask a question
safe if I switch to kernel mode
on MSI AFTERBURNER
or do you has a guide about setting on msi afterburn
18 Oct 2013   #7
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
So is everything ok now ?
18 Oct 2013   #8
linnemeyerhere
Quote   Quote: Originally Posted by AIMAN SNK View Post
now switch to ON
on MSI AFTERBURNER
I would open a new thread regarding the Afterburner and if the PSU is working then mark this thread solved and good job !
18 Oct 2013   #9
Britton30
Microsoft MVP
Yes for After Burner issues post a new thread here: Graphic Cards - Windows 7 Help Forums
18 Oct 2013   #10
AIMAN SNK
Quote   Quote: Originally Posted by Britton30 View Post
ok thank you for help
Bought new Power Supply Unit, won't power on. Did I buy the wrong one?
I have a Corsair CX430M PSU with 4 slots to connect in the back. CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com & bought a new Antec BP550 Plus PSU, which has 5 slots to connect to. Antec BP550 Plus ATX12V V2.2 80 PLUS Certified Modular...
PC Custom Builds and Overclocking
Power Supply
So the power supply went out in the old Dell xps 410, that my wife uses. It lasted a while I got it in 2005. I am going to take the one out of mine to put in it and get me a new one. I know there are other threads discussing it I just like to start my own :D The video card went out too, but I...
Power supply problem? +12V low
Hi, I'm having random crashes while playing games with my new custom build and I wanted to know if this could be my PSU's fault. Check this out. http://i.imgur.com/XHPDP.png I've tried everything and I think this is a hardware problem.
Hardware & Devices
Hardware Power Consumption-Picking a new Power Supply
Ok, so it's time again for me to pick a new power supply, however, I'm in need of some help determining the appropriate wattage for my hardware setup. AMD Phenom II X4 955 45nm AM3 GSkill Ripjaw X 16.0 GB Dual-Channel DDR3 @ 668MHz (9-9-9-24) Corsair TX750w (I dont think its the V2) ASUS...
Hardware & Devices
Power Supply Upgrade/Problem
Hi everyone. My original problem, i am sure is my power supply. However i would love a second opinion. I have just upgraded to the cross hair V main board. My computer has been restarting randomly during intensive game play. it didn't do this before my upgrade. my PSU is 500w but ridiculously...
Hardware & Devices
Power Supply
I just installed a new power supply in my computer today. My original bad one had about 3 SATA power connectors. I only need 2. I have my hard drive powered up obviously, but the two connectors on the new PSU are too close together to reach. Is it possible to cut one of the connectors...
Hardware & Devices
