Windows 7: DRAM_LED and BOOT_DEVICE_LED is ligthing up when i boot.
22 Oct 2013   #21
m0nk3n
Windows 7 Ultimate 64 Bit SP1
AHCI. it was always ahci. the newest but when i try to upgrade the firmware on it it just hangs. it did help. but then i reinstalled the driver and no glitching yet.
22 Oct 2013   #22
Slartybart
Ok, thanks. To recap:
  • Machine boots OK
  • BIOS HD always AHCI
  • The mouse firmware hangs
  • Uninstall mouse driver did help
    • Reinstalling the mouse driver seems to have corrected the glitch.
Is there still an issue that members need to address?
I think the LEDs lighting at boot is normal as long as they don't stay lit. Post# 9
Please advise on the current state of the LEDs
Bill
22 Oct 2013   #23
m0nk3n
they dont stay lit. mouse firmware hangs. i have a thread in the BSOD department but i havent had one for ages since i reinstalled, so im gonna mark that as solved. and this one as solved. thank you 7even forums
22 Oct 2013   #24
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Quote   Quote: Originally Posted by m0nk3n View Post
no its not ticked. and all the other mice are broken.
There's no way to confirm your mouse is good/bad then. Hardware fails, you can't assume "it's not the mouse". If possible get a cheap one and try it.
22 Oct 2013   #25
m0nk3n
i thought about just unplugging it if it happens again and replug it to see what happens. if that fails i'll just buy a new one. since the firmware update section in it doesnt work since it just hangs.
22 Oct 2013   #26
Slartybart
Thanks for the updates m0nk3n.
Good to hear that you're not having BSODs now.
You might contact Steelseries about the firmware update tool hanging. Or check their forum to see if others experience the hang.
Rolling back a driver helps in some cases.
I have to say "That's quite an awesome machine you built"
Bill
22 Oct 2013   #27
m0nk3n
thank you. i will ask steelseries about this. if they say its no good, i'll get a new mouse. i seached about others hanging but there was one thread about someone had the firmware hanging but it wasnt a diablo mouse so...
25 Oct 2013   #28
m0nk3n
i put the mouse in the usb 3.0 port and it updated 100%
25 Oct 2013   #29
Slartybart
That's interesting! Glad to hear you figured it out.
Dual Boot: Win7: Boot Manager Status: 0xc000000f boot selection failed
Hello, I have dual boot in my laptop with Ubuntnu 14.04 LTS and Windows 7 Home Premium 64 bit. Today after working on Ubuntu I restarted and switched to Windows and as soon as it logged in I noticed the battery was 0%. I thought maybe it was some kind of glitch or something (silly me!) so I just...
General Discussion
Win 7 , Ubuntu dual boot, windows wont boot, startup disk doesnt help
Hi a couple of months ago my system crashed, windows 7 wouldnt boot, and I misplaced my installation disk. I had the problems several times since obtaining the computer several years ago. (Lenovo IDeaPad y450). I attributed the problem to what I believed was a bad hard disk, so I replaced it with a...
General Discussion
Boot Freezes - Can only boot using Hirens Boot CD
I can only boot my machine using Hirens Boot off the hard drive. I have included 2 videos showing the issues. It loads to a Windows 7 screen but the ms colored flies / windows animation never loads. It freezes there. I've run the Windows 7 "upgrade" to resinstall install Windows 7. I didn't...
Installation & Setup
Boot Priority & Boot Device Control for New SSD as boot drive
After reading through lots and lots of posts and tutorials, I'm still a little confused. I worked for a carpenter one summer when I was a kid and he stressed the philosophy of measuring twice and cutting once as a rule to live by. So, before I fire up my saw, I thought I would seek a little...
Can't boot, boot into safe mode or boot from dvd
So I have been trying to get my computer running for a few days now. At first it wasn't booting at all, it would be a black screen with a blinking cursor. I have cleared cmos a few times, turned psu off, drained charge from psu, turned psu back on and got it working that way for about 10 minutes,...
General Discussion
Won't boot unless I use "EDIT BOOT OPTIONS (F10)" at boot screen
In order to get my laptop running I have to press F10 at the boot, which brings me to a screen that says: EDIT BOOT OPTIONS edit windows boot options for: windows 7 path: \windows\system32\winload.exe partition: 3 hard disk: 350f350f ]
BSOD Help and Support
