DRAM_LED and BOOT_DEVICE_LED is ligthing up when i boot.
Page 1 of 3 123 LastLast
  1. Posts : 125
    Windows 7 Ultimate 64 Bit SP1
    i dont know what to do with this. i removed the bad write header hdd.
    the ram is showing 16gb on post. i got a new ssd like 2 months old aprox...
    fresh install of windows 7 couple weeks since i installed it.
    and sometimes when i hit start button and am going to click on my computer. and it auto clicks it for me and when i try to open programs like ccleaner when i eventually got there it opens like 5 of the same tasks and everything keeps blinking.
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Double check all the settings in Control Panel\All Control Panel Items\Ease of Access Center.
    You could try a different/new mouse too.
  3. Posts : 125
    its not the mouse. i even use the "windows" key to open the start menu and hovers over something and it opens it. mouse is a steelseries diablo 3 mouse.
    so everything is off or disabled in ease of access center.
    but i can try next time its starts this to deconnect the mouse.
  4. Posts : 24,479
    Try unistalling the mouse software, I have a steel series Sensei and it caused problems.
  5. Posts : 125
    ok its uninstalled.
  6. Posts : 24,479
    And the result?
  7. Posts : 6,741
    What colour are the DRAM and BOOT_DEVICE LEDs when they remain lit? And are you actually able to boot when they're lit?
  8. Posts : 125
    nothing happened yet with the glitching. it happens sometimes when i lock the computer and re log in.
    they are red... i think its not a good thing. i can boot. nothing wrong with that. i have pressed the MEMOK (GO button) but nothing changes.
  9. Posts : 24,479
    Are you new to using an ASUS board? They have 4 red LEDs which light up in sequence during each boot. In this order, CPU, RAM, GPU, HDD, when the HDD LED goes off it has handed off to the OS and w7 starts. IF an LED stays on and doesn't boot it means there is some issue with that component.
    The Z77 WS work station board uses blue LEDs.
  10. Posts : 21,004
    Well my two cents worth have you tried a sfc yet? If not do so
    https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    but do not do chkdsk on the SSD mate.
    If you have not scanned for malware try these
    http://www.superantispyware.com/
    http://www.malwarebytes.org/products/malwarebytes_free/
    http://www.bleepingcomputer.com/download/adwcleaner/
    download from bleeping computer
    delete any crap they come up with
    It might even be worth running the TDSS Killer from this list
    Free Malware Removal Tools
    scanning is purely to eliminate any possibles.
