DRAM_LED and BOOT_DEVICE_LED is ligthing up when i boot.
Page 3 of 3 FirstFirst 123
  1. Posts : 125
    Windows 7 Ultimate 64 Bit SP1
       #21
    AHCI. it was always ahci. the newest but when i try to upgrade the firmware on it it just hangs. it did help. but then i reinstalled the driver and no glitching yet.
  2. Posts : 6,458
       #22
    Ok, thanks. To recap:
    • Machine boots OK
    • BIOS HD always AHCI
    • The mouse firmware hangs
    • Uninstall mouse driver did help
      • Reinstalling the mouse driver seems to have corrected the glitch.
    Is there still an issue that members need to address?
    I think the LEDs lighting at boot is normal as long as they don't stay lit. Post# 9
    Please advise on the current state of the LEDs
    Bill
  3. Posts : 125
       #23
    they dont stay lit. mouse firmware hangs. i have a thread in the BSOD department but i havent had one for ages since i reinstalled, so im gonna mark that as solved. and this one as solved. thank you 7even forums
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #24
    m0nk3n said:
    no its not ticked. and all the other mice are broken.
    There's no way to confirm your mouse is good/bad then. Hardware fails, you can't assume "it's not the mouse". If possible get a cheap one and try it.
  5. Posts : 125
       #25
    i thought about just unplugging it if it happens again and replug it to see what happens. if that fails i'll just buy a new one. since the firmware update section in it doesnt work since it just hangs.
  6. Posts : 6,458
       #26
    Thanks for the updates m0nk3n.
    Good to hear that you're not having BSODs now.
    You might contact Steelseries about the firmware update tool hanging. Or check their forum to see if others experience the hang.
    Rolling back a driver helps in some cases.
    I have to say "That's quite an awesome machine you built"
    Bill
  7. Posts : 125
       #27
    thank you. i will ask steelseries about this. if they say its no good, i'll get a new mouse. i seached about others hanging but there was one thread about someone had the firmware hanging but it wasnt a diablo mouse so...
  8. Posts : 125
       #28
    i put the mouse in the usb 3.0 port and it updated 100%
  9. Posts : 6,458
       #29
    That's interesting! Glad to hear you figured it out.
