Windows 7: DRAM_LED and BOOT_DEVICE_LED is ligthing up when i boot.
21 Oct 2013   #1
m0nk3n
Windows 7 Ultimate 64 Bit SP1
i dont know what to do with this. i removed the bad write header hdd.
the ram is showing 16gb on post. i got a new ssd like 2 months old aprox...
fresh install of windows 7 couple weeks since i installed it.
and sometimes when i hit start button and am going to click on my computer. and it auto clicks it for me and when i try to open programs like ccleaner when i eventually got there it opens like 5 of the same tasks and everything keeps blinking.
21 Oct 2013   #2
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Double check all the settings in Control Panel\All Control Panel Items\Ease of Access Center.
You could try a different/new mouse too.
21 Oct 2013   #3
m0nk3n
its not the mouse. i even use the "windows" key to open the start menu and hovers over something and it opens it. mouse is a steelseries diablo 3 mouse.
so everything is off or disabled in ease of access center.
but i can try next time its starts this to deconnect the mouse.
21 Oct 2013   #4
Britton30
Microsoft MVP
Try unistalling the mouse software, I have a steel series Sensei and it caused problems.
21 Oct 2013   #5
m0nk3n
ok its uninstalled.
21 Oct 2013   #6
Britton30
Microsoft MVP
And the result?
21 Oct 2013   #7
Boozad
What colour are the DRAM and BOOT_DEVICE LEDs when they remain lit? And are you actually able to boot when they're lit?
21 Oct 2013   #8
m0nk3n
nothing happened yet with the glitching. it happens sometimes when i lock the computer and re log in.
they are red... i think its not a good thing. i can boot. nothing wrong with that. i have pressed the MEMOK (GO button) but nothing changes.
21 Oct 2013   #9
Britton30
Microsoft MVP
Are you new to using an ASUS board? They have 4 red LEDs which light up in sequence during each boot. In this order, CPU, RAM, GPU, HDD, when the HDD LED goes off it has handed off to the OS and w7 starts. IF an LED stays on and doesn't boot it means there is some issue with that component.
The Z77 WS work station board uses blue LEDs.
21 Oct 2013   #10
ICIT2LOL
Well my two cents worth have you tried a sfc yet? If not do so
but do not do chkdsk on the SSD mate.
If you have not scanned for malware try these
http://www.superantispyware.com/
http://www.malwarebytes.org/products/malwarebytes_free/
http://www.bleepingcomputer.com/download/adwcleaner/
download from bleeping computer
delete any crap they come up with
It might even be worth running the TDSS Killer from this list
Free Malware Removal Tools
scanning is purely to eliminate any possibles.
Search this Thread:
Advanced Search
Dual Boot: Win7: Boot Manager Status: 0xc000000f boot selection failed
Hello, I have dual boot in my laptop with Ubuntnu 14.04 LTS and Windows 7 Home Premium 64 bit. Today after working on Ubuntu I restarted and switched to Windows and as soon as it logged in I noticed the battery was 0%. I thought maybe it was some kind of glitch or something (silly me!) so I just...
General Discussion
Win 7 , Ubuntu dual boot, windows wont boot, startup disk doesnt help
Hi a couple of months ago my system crashed, windows 7 wouldnt boot, and I misplaced my installation disk. I had the problems several times since obtaining the computer several years ago. (Lenovo IDeaPad y450). I attributed the problem to what I believed was a bad hard disk, so I replaced it with a...
General Discussion
Boot Freezes - Can only boot using Hirens Boot CD
I can only boot my machine using Hirens Boot off the hard drive. I have included 2 videos showing the issues. It loads to a Windows 7 screen but the ms colored flies / windows animation never loads. It freezes there. I've run the Windows 7 "upgrade" to resinstall install Windows 7. I didn't...
Installation & Setup
Boot Priority & Boot Device Control for New SSD as boot drive
After reading through lots and lots of posts and tutorials, I'm still a little confused. I worked for a carpenter one summer when I was a kid and he stressed the philosophy of measuring twice and cutting once as a rule to live by. So, before I fire up my saw, I thought I would seek a little...
Can't boot, boot into safe mode or boot from dvd
So I have been trying to get my computer running for a few days now. At first it wasn't booting at all, it would be a black screen with a blinking cursor. I have cleared cmos a few times, turned psu off, drained charge from psu, turned psu back on and got it working that way for about 10 minutes,...
General Discussion
Won't boot unless I use "EDIT BOOT OPTIONS (F10)" at boot screen
In order to get my laptop running I have to press F10 at the boot, which brings me to a screen that says: EDIT BOOT OPTIONS edit windows boot options for: windows 7 path: \windows\system32\winload.exe partition: 3 hard disk: 350f350f ]
BSOD Help and Support
