New Battery toggling between "charging" and "not charging"
  1. Posts : 2
    Windows 7 Home Premium 32bit
    Hi
    I replaced the battery on my Gateway MA8 with a brand new one (non OEM). With the laptop turned off, the new battery charged well without any problems. But when I charge the battery with the laptop turned on, I see the battery icon changing from "plugged in-not charging" to "not plugged in" to "plugged in-charging" and the cycle repeats. The charging LED indicator also keeps turning off and on, following the icon messages (this indicator was constantly on when charging with the laptop turned off). Looks like the battery charging is getting messed up when Windows 7 is trying to monitor the status.
    Applications also are exhibiting a strange behavior during this time. I had started a virusscan and whenever the battery icon changed to "not plugged in", the virusscan used to pause and would resume when the icon changed to "plugged in-not charging" or "plugged in-charging". Very weird!
    I uninstalled the Battery ACPI driver through Device Manager, but that did not help. The other battery drivers are reporting up-to-date versions.
    I tried removing the battery altogether and connected directly to the power. It works for sometime and then suddenly the laptop shuts off. So cannot use that solution either.
    One other data point is that the original battery was 11.1V 4800 mAH (53 watt hours), whereas the replacement one is 10.8V 5200 mAH (56 watt hours). But it has the correct battery model number. Could this be a cause? I had thought this difference should not matter.
    Any help on how to fix this?
    Thanks very much.
  2. Posts : 21,004
    Hello and welcome drpvrvena mate sounds lie you have a dud battery my friend the voltage difference could be a possible cause even though it is only 0.3v.
    The cycling stuff is also in my humble opinion indicative of a faulty battery. Now battery drivers?? I have never heard of such a thing I mean a battery is a battery I think maybe you mean something to do with the charge circuitry
    But just a matter of interest try running these
    https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    https://www.sevenforums.com/tutorials/433-disk-check.html
    http://www.superantispyware.com/
    http://www.malwarebytes.org/products/malwarebytes_free/
    http://www.bleepingcomputer.com/download/adwcleaner/
    download from bleeping computer
    in that order delete any rubbish the malware scans find
    Personally I would dump the AVG or at least pause it and see what happens with that charge problem.
    If you ant to change to another security then let us know plenty of free suites and better than AVG (again not hard in my mind) .
  3. Posts : 2
    Thanks for the reply. A bad battery was my first thought too, but it is charging fine when the laptop is turned off. The problem is only when the laptop is turned on. Looks like some problem when Windows is actively trying to monitor the battery status....
  4. Posts : 21,004
    Yes mate thats why I reckon those scans will probably pop something up:)
