Windows 7: Power options/brightness problem!!!!
21 Oct 2013   #1
paulobao
Windows 7 Professional 64 bit
I've this issue from day one! I bought my Toshiba Tecra R840 almost 2 years ago (Win7 Pro, i7, 8GBRAM, 512 GB SSD,...). What about the issue:
My Power Options are:
when running on battery: brightness=40%
when plugged in: brightness=100%
If I click apply, this would be ok for a while (I will say 24 hours). But then for some reason (and I do not change anything) the brightness will go to 40% no matter if I running battery or if I'm plugged! And I will need to adjust brightness again!
Any help?
Regards,
paulo
23 Oct 2013   #2
paulobao
Problem solved for good :-)
Cheers,
paulo
Notebook display brightness low when plugging out power cable?
As long as the power cable is plugged in in my notebook the brightness of my display is fine. But when I plug it out and use the battery the brightness becomes suddenly darker. Why? How can I prevent this switch-to-dark-screen? I found no corresponding option in the power plans
Hardware & Devices
Power options problem
Have a Toshiba Satellite L550 i5 8GB RAM 120GB Crucial M4 running Home premium 7 and I am having a problem with the screen going bright on unplugging the power supply and onto battery then reverting back to a dimmer screen when power is plugged back in. Have tried all the settings in Power...
Hardware & Devices
Power Options Problem
I am using Windows 7 32bit and although I am setting the power options to turn off the display after 10 minutes nothing happens and the screen does not turn off Any help would be much appreciated regards Brian
Performance & Maintenance
How to set Advanced options in Power Options (64 bit Ultimate)
I have an older Belkin F6C1500-TW-RK UPS and the mfg has not offered software management for the Win 7 64bit OS. I want to let Win 7 manage the battery and shutdown. I set the High Performance under Power Options to turn off display and put the computer to sleep after 3 minutes as a test. I yanked...
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
Adjust Brightness brings up Power Plan settings!
I just noticed that in Display properties, the Adjust Brightness brings up the power plan settings....
General Discussion
