Windows 7: Startup Problem - Start up Loop - c drive is system reserved
04 Nov 2013   #1
npsays
I have been breaking my head with win 7 startup, which keeps going into loops. Initially I got the captioned error " C drive is system reserved" with very little space in my c drive. I checked information and repaired C drive using diskpart . I can access the c drive contents through command prompt now (which I wasn't able to access earlier), but still the start up won't go beyond the windows logo screen.
following is the problem signature log:
Problem Signature:
problem event name: startuprepairoffline
problem signature 1 : 6.1.7600.16385
problem signature 2 : 6.1.7600.16385
problem signature 3 : unknown
problem signature 4 : 21200319
problem signature 5 : External Media
problem signature 6 : 10
problem signature 7 : NoBootFailure
OS version : 6.1.7600.2.0.0.256.1
local id : 1033
Have tried to repair through installation Cd, doesn't help. Please advise
05 Nov 2013   #2
TVeblen
In addition to breaking your head there is a good possibility you have been breaking your computer. It is best to "come clean" and tell everything you have done to this point (what was the original issue, what have you tried to fix it). This will yield better answers.
But assuming you have not deleted partitions or overwritten anything you could try a Startup Repair. You may need to run it 3 or 4 times depending on the extent of damage encountered.
And be sure to disconnect any additional hard drives before running it. Only the HDD with the operating system on it.
Startup Repair
Startup Repair - Run 3 Separate Times
System in startup repair loop
My desktop started acting up yesterday. Now starts, goes directly to black screen saying windows in loading data then to the start up repair tool. Here it says it cannot fix the issue and gives option to shut down, restart or go to further repair options. After running a SFC scan and that saying it...
Backup and Restore
Windows Startup Repair from System Reserved partition does not work
When I press F8 and run Startup Repair instead of Recovery console normal Windows is booting. I have just System Reserved partition and then one C: partition. Here's my BCD to check - what should be corrected here ?
Installation & Setup
Startup repair/system restore loop
I'm running Windows7 on a Toshiba Satellite A665-S6067 I believe I'm currently stuck in a startup repair/system restore loop, I stayed up late last night trying every trick in the book to fix it that I know of, but to no avail. I'm currently a college student and I have VERY important files...
Backup and Restore
System reserved partition (system, active) on Slave drive
Current Master Drive (C:) : OCZ-VERT EX2 SCSI (my SATA Drive) - 60 GB Current Slave Drive (D:) : WDC WD10EARS-00Y5B1 ATA - 1 TB My computer used to have a boot file set on my slave drive, but OS installed on my master. So i eventually reformatted it so that my boot AND OS was installed on my...
General Discussion
startup problem - startup loop/corrupt registry
I am trying to fix my sisters laptop, which is a hp pavilion dv6 2100nr. She told me she dropped it while it was turned on and it wont start up anymore, it also has a new issue causing the system to only power on or stay on when the laptop is charging. I started by running windows start up which...
BSOD Help and Support
system reserved partition on second drive
My computer came with a 1TB drive pre-installed with windows 7 home premium and no windows install disk. I immediately created the system restore dvd's so at least I have a default copy of windows. From past experience I prefer to have a smaller drive with windows (which i loaded from the...
General Discussion
