Windows 7: Laptop has problems with charging unless I wiggle the charging pin.
11 Nov 2013   #1
topazkitty
Windows 7 Home Premium 64 bit
Hi, I'm having problems charging my gateway laptop unless I wiggle the charging pin and power brick a certain way. I have tried replacing the charger and battery. It doesn't help. Also If I run on straight AC with no battery the laptop will shut off if it moves due to the contact problem. Does any one know why this happening?
Thanks for the Help.
Also its a gateway t-6859 laptop.
12 Nov 2013   #2
rvcjew
7 Pro x64, 10 Pro x64
how old is the laptop sounds like your ac in port has de-soldered from the psu part of the motherboard. its the most common thing to break on laptops since they get a lot of stress from the cables pulling on them or they are built cheap either way. is is it still in warranty?
12 Nov 2013   #3
topazkitty
This laptop is 3 years old, I got it for free last year because the owner didn't want it. I have no warranty. I did not have this problem until last month or so.
12 Nov 2013   #4
topazkitty
Also The charging pin just got really hot and burned my finger
12 Nov 2013   #5
rvcjew
was the pin inside the laptop when it burned you it sounds like you need to get he ac component of your laptop replaced for sure.
12 Nov 2013   #6
topazkitty
It was the little metal piece that goes into the laptop. Also when that happened I was trying to get it to make contact with the pin.
12 Nov 2013   #7
Mellon Head
If it's getting hot enough to burn you it could be a fire hazard. Please get the laptop serviced by experienced personnel. And please don't use it until you do.
12 Nov 2013   #8
topazkitty
Thanks, Guys I just bought a new laptop from Amazon for school. What do you guys think, I know it runs android, but that's all I need because I have other computers at home here. and My college has a lot of computer labs.
Amazon.com: WolVol 7 inch Netbook Mini Laptop Tablet (Black) 8 GB Hard Drive Latest Android 4.1 Model Touch-Screen with WIFI,Camera,Netflix,HDMI Port. Authorized and Pre-loaded with ToonGoggles Cartoon Videos (Includes: Charger, Wired Mouse, Velvet C
12 Nov 2013   #9
Computer0304
Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
I think it would have been better if you get a Android tablet like the Nexus 7 and a Bluetooth keyboard or a Surface.
12 Nov 2013   #10
topazkitty
The nexus 7 is on my christmas list, but I would be afraid to bring it too school because its expensive and fragile, I would also perfer to have the keyboard built in to the unit.
ac not charging in 1st laptop, only charging when off in 2nd laptop?
Original AC wont charge or pass power to my lenovo2010... electricity goes through for a second before to stop. So i isolated the problem, by using the ac in another lenovo 2005, which charges when turned off, but not when turned on?! So AC's the buggger.... but that kinda bug is mesmerizing...
Hardware & Devices
Dell laptop not charging..getting message plugged in not charging
Dell laptop not charging..getting message plugged in not charging I brought Dell Inspiron 14R laptop 2 years back . My laptop is not getting on with battery..only when power cable is plugged in its getting on..but getting message saying "plugged in not charging"...replace the battery. Is this an...
Hardware & Devices
Charging laptop BATTERY!
I bought a HP pavilion dv6 laptop! I just want to know is it bad if I leave my laptop charger connected all day even if its fully charged? :sarc:
Hardware & Devices
Something to tell me when my Laptop isn't charging
Hi, my laptop has a slightly broken charge slot. As in i have to toggle it a bit it get the charging to work and if a strong vibration occurs it could stop charging anytime. I usually play video-games in full screen allot, so I can't tell if my charging suddenly stops or not. I need a way for it to...
General Discussion
Laptop Not Charging!!!
Hi I have a Dell Studio XPS 1645 which I have had for about 2 years so its out of warranty. My battery has stopped charging so the laptop has to be plugged in constantly. I have read about a lot of issues on the internet where this has happened with various fixes been: Replacing Motherboard...
General Discussion
Laptop Battery not charging past x %
Hey guys, I have an Acer Aspire 5741-6073, and it would not charge past 40%, even with the power cord plugged in for several hours. I reported the issue to acer, they asked me to drain the battery then press and hold the power button for 30 seconds to discharge any remaining charge. Then while...
Hardware & Devices
