Windows 7: Noise - Fan problem?
13 Nov 2013   #1
kbronski
Windows 7 Pro x64
My laptop is starting to make a sound and I think it's the fan. When I put the fan port to my ear, I can hear some SLIGHT grinding, and occasionally it'll act up and make a loud grinding sound that is reminiscent of a DVD drive crossed with an old processor click. I do believe it is my fan, but to make sure, does anyone have insight as to what something like this may be?
And, before anyone asks, my computer:
HP Pavilion dv6t-6000 Quad Edition
Owned since May 2011.
This is my first hardware issue.
14 Nov 2013   #2
rvcjew
7 Pro x64, 10 Pro x64
sounds like a fan with misaligned bearing and hopefully not your hdd, if you use hd tune what does your smart data show? does it have any warnings? does it make this noise when you are in the bios? here is a video of how to get to the fan it should be the same chassis yours uses i believe (don't open it if your still under warranty let hp take care of it.). HP Pavillion dv6 Complete Disassembly and Reassembly. 2011 Laptop - YouTube
14 Nov 2013   #3
kbronski
Windows 7 Pro x64
Everything checks out okay on HD Tune.
I'll check the fan and see if something's up with it. It could just be getting knocked around from carrying the laptop so much.
15 Nov 2013   #4
madcratebuilder
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
Lap tops seem to pick up more dust and lint than a pc. You may get lucky and clean the fan with a can of air. More than likely you well need to pull the fan, clean and service it, even replace it. Fans are cheap and the disassemble to replace them can be time consuming. With lap tops I replace with new, it's not worth the risk of possible over heating or going inside a second time.
15 Nov 2013   #5
kbronski
Windows 7 Pro x64
Quote   Quote: Originally Posted by madcratebuilder View Post
it's not worth the risk of going inside a second time.
You know, taking apart a laptop isn't all that bad as long as you're careful not to break anything (i.e. those pesky plastic clips).
A zoom (White noise?) i cant get rid of, Audio problem?
Hi there, i got this problem since i reinstalled windows ultimate on my laptop. I tried reinstalling windows, tryed different drivers and still i cant get it to stop. My laptop cable is connected on to a screen and the plugs are in a grounded outlet.. This sound only comes up when i get...
Notebook random noise problem
Hello, my english is bad but I try to describe it. I have MSI CX61 2OD notebook. My notebook has random noise, it comes like from "left speaker area". I muted speakers and disabled sound card but noise keeps coming. It's not like HDD noise, more like a " cızzzt" . It's coming always in same...
General Discussion
noise from lineout, problem with Realtek ALC1200 Audio V6
Hi everyone I have Asus p6t mainboard, There has been noise on lineout, in windows XP I used Realtek ALC1200 Audio V5 mixer to mute some lines and noise disappeared. but windows 7 uses Realtek ALC1200 Audio V6 and there is no mixer (at least i couldn't find) there. How can I solve this...
xonar d2x sound card loud buzzing noise problem
I am using xonar d2x sound card and it has been good until recently when I played videos on youtube and games it gives a loud buzzing noise. Even sounds made by windows sound produces the loud buzzing noise. It also happens on sometimes when playing videos. Other than that it works fine. I tried to...
Problem - Noise front panel
Hi, I have a Asus P8Z68-V PRO with an Intel i5 2500Kand have a very annoying trouble. The front panel of my tower (Nox Blaze) when i connect my headphones to audio out make a very low profile noise, it seems like electromagnetic impulses ... When the CPU is used at 100% the noise...
mouse problem with loud noise
Hi I hope you can help me. Got a new computer a couple of months ago with HID-compliant mouse supplied (optical - sensor plugs in the back). Loaded in Windows 7 and for a couple of months everything was fine. Then yesterday, I was listening/watching a video when a continuous loud pitch...
Hardware & Devices
