Windows 7: Laptop Battery 0% avalailable plugged in charging but its not.
14 Nov 2013   #1
saffa
Windows 7 Professional x64
I don't know how to fix this one but if i unplug the power the laptop turns off automatically and it's not an OS error i think because i have Windows XP dual booted and that say's the same thing anyone please help.
http://www.sevenforums.com/attachmen...1&d=1384453550
14 Nov 2013   #2
rvcjew
7 Pro x64, 10 Pro x64
how old is the laptop? seems the battery is dead, does it start up if you have the battery out and plugged in? what model of laptop? EDIT: is it the one in your specs?
15 Nov 2013   #3
saffa
Thanks for the response yes it is the same as the spec's went to check if the charger is alright and it is still responding voltage of 19.45 for the charger and its from march 2010 by the way but not used a lot since I usually have it plugged into the wall anyway.
15 Nov 2013   #4
saffa
and yes it does work without the battery
15 Nov 2013   #5
rvcjew
interesting if you boot for instance a live distro of ubuntu does ubuntu also say it has no battery charging? it could just be a power management issue in windows but its probably your battery has just degraded form being constantly plugged in (that's not good for them, they need to discharge every once and a while to stay healthy). EDIT: forgot xp says the same thing you need a new battery then or the sensor in it for reporting its power level has failed. either way you need a new one it seems, is that one internal? what is the model of your laptop?
15 Nov 2013   #6
saffa
The model number is VPCEB16FG and it's an external battery thank god, I saw on Sony websites prices from $149 but hey they gotta make a business some how don't they.
15 Nov 2013   #7
rvcjew
actually what model is on the battery it self? EDIT: your battery is > VGP-BPS22 so from google you can find many of them for about 40 bucks even if its not a sony if its the same specs its still good if its a decent brand. is yours 3500mah or 4400mah?
16 Nov 2013   #8
saffa
I think it's the 3500mah cause it only lasted 40min on hgh end gaming.
16 Nov 2013   #9
saffa
and about 1 hour 50 min for word process and browsing is that nomal for this type of battery ?
16 Nov 2013   #10
whs
Microsoft MVP
I had the same problem until I discovered that it was not charging whilst I was running the OS. Shut off the OS and see whether it charges. But wait a couple of hours to check status.
Asus Battery Issues, plugged in not charging.
I have an Asus x54c, windows 7. My battery had signs about needing to be replaced, and I bought a new adapter and kept charging it. Although it did not make much of a difference, it still had some percentage. I now have 0% available, plugged in and charging lol except it really is not charging. Any...
Hardware & Devices
96% Battery plugged in but not charging
Acer laptop 2 months old I did the followings but did not fix it : Unplugged the machine Removed the battery Plugged everything back in ( except the battery ) and loaded the machine Turned off the machine Put the battery back in.
Performance & Maintenance
Battery says plugged I not charging
My dell inspirion says plugged In not charging I have replaced the motherboard,battery,and charger please help
Hardware & Devices
Alienware Battery - Plugged in, not charging
Over the last week, my alienware M11x laptop has refused to charge. Each time, the issue would resolve itself after a few minutes, but the problem has persisted for several hours now and my computer is now at 9% battery. I have already tried removing, unplugging and and moving the AC adapter,...
Hardware & Devices
Dell laptop not charging..getting message plugged in not charging
Dell laptop not charging..getting message plugged in not charging I brought Dell Inspiron 14R laptop 2 years back . My laptop is not getting on with battery..only when power cable is plugged in its getting on..but getting message saying "plugged in not charging"...replace the battery. Is this an...
Hardware & Devices
Laptop Battery - Plugged in, not charging.
As per the thread title, the battery is recognised as being present, but is not charging, and when the power is disconnected, will not run on battery power. I have come to the conclusion that it is most likely a hardware issue, see below. Comptuer is the one in my 'System Specs', just on 2...
Hardware & Devices
