Windows 7: Problem with Verbatim USB 3.0 portable drive and USB 3.0 port
18 Nov 2013   #1
lumzi23
Bought a brand new Verbatim Store 'n' Go Portable HDD. It was to be my first taste of USB 3.0 on my (nearly) year old gaming system. When I connected it had a couple of problems.
1. The first USB 3.0 port (front side) I connected it to kept connecting and disconnecting. So I moved to another.
2. This second (front side) port seemed to work but when I tried to transfer a file it was quite slow.
3. Eventually my computer stopped failing to recognize the drive.
4. Attempts to format or error check the drive when connected to the to the blue USB 3.0 port failed.
5 When I transferred to the USB 2.0 port to error check and format, both worked in in disk management.
6. I also downloaded the USB 3.0 drivers from the Intel site.
7. I think I may have connected something poorly when I initially built the system, however upon opening the system I didn't see anything out of the ordinary. It is my first build so I could be wrong. As far as I know there is only one fairly large connector that connects to a blue USB thingy on my motherboard. The cable is usually blue but mine is black but I was under the impression that this is not unusual. My motherboard is the P8Z77-VLX from Asus and my case is the Cooler Master 690II (RC-6N2A-KNN5, I believe).
(Extra: I also should not that drive shows up as a Toshiba in the device manager. I confirmed by disconnecting and reconnecting it. Also when the drive seems to work normally on USB 2.0 now.)
(Extra 2: OS is Windows 7 64bit and the USB 3.0 ports in the past have worked fine as USB 2.0 ports. The problem [to my eyes] seems to be a USB 3.0 thing specifically)
(Extra 3: I can't seem to find how to enable USB 3.0 in the Bios. I see stuff about USB 3.0 legacy mode and 'Intel USB2.0 EHCI controller' but no USB 3.0 on switch. I have the most recent version of my Bios.)
It is also worth mentioning that the drive dropped a couple of times while still its packaging.
If any assistance could be provided it would be greatly appreciated.
18 Nov 2013   #2
carwiz
Windows 7 Pro-x64
Start by installing the drivers that came with your ASUS motherboard. Why would you install Intel drivers?
If you don't use a USB3 interconnect cable, you won't get USB3. ALL USB3 cables will have a blue insulator at the plug whether the cable itself is black, green, red, pink or whatever--It's a standard.
Make sure the front panel is capable of USB3. Just because you connect it to a USB3 hub doesn't mean it becomes USB3.
18 Nov 2013   #3
lumzi23
Quote   Quote: Originally Posted by carwiz View Post
I installed the drivers that came with my motherboard initially but it didn't work (which were labelled Intel in any case). The I installed the Intel drivers (I think) then I installed the latest drivers from Asus' website. Just to be sure I have now reinstalled the USB driver that came with my mobo. Still doesn't work.
Also, the mouth of the USB cable is blue. I have confirmed it.
The front of my case has blue USB ports if that is what you mean (sorry I don't know the tech lingo all that well ).
18 Nov 2013   #4
MilesAhead
Windows 7 32 bit
I would ask someone to plug in their USB 3.0. If it works it might be the drive. I don't trust "sliding guts" drives. I got a Verbatim due to the price. But inserting into a tight connector kills my thumb. Plus I think sliding guts is too fragile. I like AData USB 3.0 "gray tube" for physical design.
18 Nov 2013   #5
lumzi23
Quote   Quote: Originally Posted by MilesAhead View Post
I don't know anyone with a USB 3.0. In fact this drive I have is the first one I have probably ever handled.
Edit: I had contacted Verbatim and they gave a firmware updater but it could find the drive. I have now asked them if it is possible to install the firmware needed some other way. I don't know if that is the problem. I'll keep you posted.
Also, about my bios question. Is it unusual not to see an on button for USB 3.0 in the bios?
19 Nov 2013   #6
MilesAhead
Windows 7 32 bit
Then try your drive on another PC. Go to the library if need be. If it won't take the update chances are it's dead doornail. Those things aren't very sturdy as they are made as cheaply as manufacturer's can devise.
19 Nov 2013   #7
dsperber
I have four Verbatim Store 'n' Go 2TB USB 3.0 drives in use on two desktops and a laptop. I use them for my backups. I've also installed five more of them on other machines for friends and family. They are wonderful, and reliable (no matter what manufacturer's SATA-III drive is inside them), and they are the only such external drives I will buy. I especially appreciate the "Green Button" software that spins them down after 10 minutes of inactivity. I also like the ON/OFF rocker switch on the case, something which is absent on other external USB drives I've seen (e.g. one from Hitachi).
I have two in use on my ASUS P8Z77-V Pro motherboard machine (one's a Samsung drive inside, and the other is a Seagate), plugged into two of the stock rear USB 3.0 ports (with the blue tongue). Note that I'm not using the special-purpose USB ports (e.g. for flashing BIOS), but rather the standard USB 3.0 ports. Nary an issue.
No special drivers whatsoever are required. Plug in the drive, and assuming your Windows 7 is behaving properly it should automatically install whatever it wants to install... which is actually a Microsoft driver for the external USB drive. The USB 3.0 Root Hub is supported by Intel drivers (as part of the chipset support) but this should have been configured as part of the Win7 installation and device discovery when you built your machine. I did opt for an ASUS Turbo Boost USB 3.0 driver myself when installing the ASUS software after Win7's install, which came from ASUS and I think is supposed to improve performance even further.
If things are working properly and you plug it into a USB 2.0 port and the device is correctly recognized, Windows will tell you that you can get better performance if you plug it into a USB 3.0 port.
Don't know what else to say, other than that I've never had any problem with these drives. Also, I've even installed them on older machines (including WinXP) where I've had to install a Transcend TS-PDU3 PCIe USB 3.0 adapter to use them optimally. Again, not a problem.
19 Nov 2013   #8
MilesAhead
Windows 7 32 bit
It might be helpful if the OP posts a link to the product he's talking about. "Store 'n go" seems to cover a lot of ground.
19 Nov 2013   #9
lumzi23
Portable Hard Drive 500GB USB 3.0 Black | Store 'n' Go
This is the one.
Edit:
@ dsperber I don't know what the problem is. A part of me is wondering if the issue is with my system.
edit @ miles: I have tried it on my laptop on the USB 2.0 ports and it seems to be working fine. I had also tried it earlier. I don't recall if I found any issues.
19 Nov 2013   #10
MilesAhead
Windows 7 32 bit
Tough to rule out damage unless you try it on another machine.
USB drive problem accessing database due to port shut down
When I have my USB drive connected to my router, no problem. When instead I have it connected directly to my PC (a laptop) (resulting in the same drive letter assigned to the drive as when connected to the router), the PC doesn't stay connected to the drive, such that after awhile I lose connection...
Network & Sharing
Verbatim external hard drive not picking up
I just bought a Verbatim 1TB external hard drive (USB 2.0, 3.5") and my PC with Windows 7 Home Premium 64bit is not picking it up. I have tested the USB port and it definitely works. I have tried searching for new devices. I have tried the hard drive on friend's PC also with Windows 7 and it...
Hardware & Devices
Portable Expansion Drive.
Hi, I have a Seagate USB3 500GB Portable Expansion Drive to accommodate my Back-ups and also any files I wish to 'transport' to another PC. I would prefer to leave the device connected to my PC except when I need to transport files. Will leaving it connected do any harm; should it be removed when...
Backup and Restore
Verbatim 1TB External drive not recognised on boot
Hi I have windows 7 with a Verbatim 1TB external drive, the system is not recognising the external drive. When I switch it off and back on again it then recognises it and loads it in My Computer. I have another external USB drive which works just fine. This problem started after I formatted the PC...
Hardware & Devices
USB Thumb Drive vs Portable HDD
Hi Everyone, I need your opinions on a purchase I'm planning to make soon. I'm in a bit of a fork as to what I'm going to get actually. A thumb drive would be more portable, so to speak rather than the portable HDD. An HDD would have way more space, however. I will mostly use this...
Hardware & Devices
New Portable Hard Drive
Just got myself a new portable hard drive made by Zynet. Every time I try to Initialize it, a box pops up saying The device is not ready? I have tried changing the USb sockets it is plugged into, to no avail? The HD is on, the pc recognises it, as it is showing up in the disk management screen....
Hardware & Devices
