Windows 7: sandisk cruzer edge flash drive 32GB will not recognise to read files
20 Nov 2013   #1
victorsj
windows 7
Hi, I am an oap with little pc knowledge. My friend has kindly downloaded some small video clips from my phone onto a SanDisk Cruzer Edge 32GB memory stick. He put a note with it to open with quicktime player. When I load the stick it goes straight to windows options for opening which of course gets me nowhere. I do have quicktime installed but can't seem to get the connection in order to open these files. Now the pc is saying it is not recognising the Sandisc.
I there a kind hearted soul out there who can give me very easy instructions re how to just open these videos onto my pc. Many thanks
20 Nov 2013   #2
SandeepP
Winndows 7 32 bit
Quote   Quote: Originally Posted by victorsj View Post
Hi victorsj,
Welcome to Seven forums.
Please let us know what happens when you connect this USB drive to this system or any other system. Kindly post a screenshot of my computer and device manager so we can check the same:
Kindly update your system specs here by following this.
Keep us posted with the results so we can advise you further.
21 Nov 2013   #3
victorsj
windows 7
Thank you for your time
Hi Sandeep, I am pleased to say that I have now sorted everything out. May I thank you for your time given to me. Regards victorsj
24 Nov 2013   #4
SandeepP
Winndows 7 32 bit
Hi victorsj,
Its great to hear that issue with the system has been resolved to your satisfaction. If you have any queries in future feel free to contacts us.
Error with nearly-new 32Gb Sandisk Cruzer Glide
It now reports itself as a Sandisk Firebird with 64Mb total and it is reported by Win7 Home Premium x64 as of type RAW, when I know it should be either VFAT or FAT32. Have scanned drive with Easeus Partition Manager (nada, except same report) and Minitool Partition Wizard Home Edition (also, same...
Software
16 GB SanDisk Cruzer suddenly becomes write protected!
Got a 16 GB SanDisk Cruizer flash drive and it did well - until I swapped my hard drive for an SSD. Since the SSD conversion, the ReadyBoost file on it does not work - Windows won't use it because I have an SSD - that' fine. The real problem is the SanDisk became write protected - can't format,...
Hardware & Devices
Sandisk U3 Cruzer Micro won't load U3 software
I've updated my U3 drive to the newest version. When I plug in it occupies J: (the "CD Drive") and K:. When I try to run the U3 launcher it tells me Windows has mounted it on a drive that was already occupied and that I can't start it. Disk management won't let me change the drive letter of...
Hardware & Devices
Backing up to a sandisk 8 gb cruzer
I have been writing before in a different forum that had kind of died out. I just bought a Cruzer Blade USB flash drive, 8 gb, to back up my computer - windows 7. It still doesn't like it. I cannot get an external hard drive and this wasn't that expensive. It says to please insert a d/dvd/or...
Performance & Maintenance
SanDisk Cruzer Flash Drive-AUTOPLAY problem
Hi, I have this flash drive USB Flash Memory - Smart Design Flash USB Drive by SanDisk U3 is built within it. As i put it in win7 i dont have the AUTOPLAY menu , but I can through the browser locate the two components of the drive under My Computer: 1-CD DRIVE SYSTEM U3 2-REMOVABLE DISK
Hardware & Devices
