Windows 7: Nothing showing on monitor after not using 2-monitor cmputer fr awhile
28 Dec 2013   #1
projecttoday
Windows & Professional 64-bit
A couple of years ago I bought a used corporate desktop PC with Windows 7 and used it for a while. Then I bought a new laptop and I haven't used the desktop since. Now I need to get a couple of programs off the desktop. But when I turn it on nothing shows on the monitor. The computer sounds like it's booting up okay.
I am using the very same monitor that I used before when it was working. (I am typing on this monitor right now (with the newer computer)). This desktop has a large port for a monitor that you connect a splitter connector to and then connect the monitor to one of the two smaller jacks coming out of the splitter connector. As I recall. when I first bought the computer I connected my monitor to a monitor port on the computer which fit the monitor's cable and it didn't work. I contacted the seller who told me to connect it to one of the splits and it worked.
But for some reason now it's not working. It could be something simple. It may have something to do with the 2-monitor configuration of which I know little.
So my question is how can I proceed toward seeing what's going on on this Windows 7 desktop computer enough to retrieve several Visual Basic programs?
29 Dec 2013   #2
Ranger4
This is probably a very stupid question, but have you got the monitor turned on?.
29 Dec 2013   #3
projecttoday
Yes.
My Monitor is not showing anything when i press the start button
after i was trying to upgrade from windows 7 to windows 8 i restarted my computer to try to upgrade it then when i pressed on the start button nothing showed up ( the screen was black ) and i usually get a "beep" when the computer turns on but this time i didnt ( i can hear the fan is on ). And i...
Installation & Setup
Windows 7 not showing option for 2nd monitor
I have just purchased a new Toshiba 32" tv to use as my monitor. It is HMDI compatible and I picked up the appropriate cable. However, my windows setup does not show an option for a 2nd monitor which I understand I need to use in order to install and use this new monitor. Please help
Graphic Cards
Disk activity not showing up in Resource Monitor?
I've noticed that Windows Media Player is thrashing my hard drive whenever I play videos, so I tried to investigate with Resource Monitor. The "Processes with Disk Activity" pane shows it reading about 4Mb/s, but there's nothing to show for it in the "Disk Activity" pane. Any ideas what's up?
Performance & Maintenance
Only one monitor showing in display settings?
I did have two showing even though I am only using one at the moment but for some reason only one showing now....any ideas? Thanks
Graphic Cards
display showing one monitor when two are conected
i have a Sapphire hd 7850 graphics card and two monitors connected to it one hdmi one dvi-d. both screens are showing the same image and when i go into screen resolution it shows only one "generic PnP montitor". this was a fresh install of windows seven and it did work before that. the driver for...
Graphic Cards
Monitor not showing up in device manager
i'm using 64 bit win 7. Monitor not showing up in device manager. my monitor is samsung 2232bw. any solution ? ty
Drivers
