Windows 7: I keep having problems with USB device not recognized.
04 Feb 2014   #1
Skeptisk
Norge
Hello guys!
So some days ago I bought an AVerMedia Game Recorder HD from a private guy on finn.no (something like ebay, but in Norway)
My problem is that when I plug the USB in my USB 2.0 and 3.0 I get this message: USB device not recognized.
I have downloaded all the newest drivers and firmwares from their website: AVerMedia.com, but It still wont work.
I know I have alle the components correctly entered because I have watched their tutorial and I actually read thru their user guide.
If anyone knows how to fix this I would be super happy!
Sorry for bad english.
- Skeptisk.
04 Feb 2014   #2
fireberd
In most cases you have to first install the device drivers and only then connect the device to the PC. If you connect it first and there are no drivers it can be "not recognized".
If you have a System Restore point that is before you first attempted to install it, roll back with that System Restore and that will give you a clean start. Then first install the drivers.
System Restore will not delete any user data or e-mails. But any programs or updates that were installed after the restore date will have to be installed again (or anything uninstalled will have to be uninstalled again).
05 Feb 2014   #3
ComputerGeek
Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
Hi @skeptisk
USB devices are detected and recognized at the USB Plug and Play bus level. If it were a game driver issue you'd be getting a "driver not found" or other driver error message.
That means your problem is somewhere between the game device firmware/hardware and the USB controllers.
If a laptop, make sure it's plugged in. like wise, the game should have power. Try turning on the game BEFORE connecting to USB. Make sure the latest chipset / USB controller drivers installed. Try connecting the game to a different computer USB. The game driver doesn't need to be installed. Just see if you can get to a "driver not found" error - would mean other computer can recognize the device.
I'm pretty sure that it isn't the first subject about it, but I didn't find any threads wich looked like mine, so I'm doing a new one. Yesterday, I was browsing the Internet like everyday of the week, and my mouse stopped working, for no reason. It just does the "tadam" (sound wich is done when we...
Hardware & Devices
USB device not recognized - but there is no usb device connected
It's recognized in device manager as "Unknown device". But I've not connected anything to pc. Also all of my usb ports are working at 1.1 speed. When I try to connect any device, I get the message "that it could work faster, if i connect it to hi-speed usb port". Any suggestions?
Hardware & Devices
USB device not recognized will NOT go away
This is getting irritating enough I am tempted to go back to XP. Every time I plug in a USB device to charge it, for example my GoPro helmet cam, or just have an empty USB cable plugged in to one of the PC's ports and leave it on my desk so its ready to plug something else - I get that...
Hardware & Devices
USB Device Not Recognized
I am getting a constant error. When the error happens I hear the usb connection alert sound and a pop box appears in the lower right corner of my screen. I tried installing the chipset drivers again and when that didn't work i did a system reinstall. The only us devices I am using is my wired...
Hardware & Devices
USB device Not Recognized
Hi I'm trying to transfer files to a USB device and it is all of the sudden "not recognized" It was working before and suddenly stopped. It used to come up as F: I have tried uninstalling and reinstalling in Device Manager, and moving usb ports. All help is appreciated.
Hardware & Devices
USB Device not recognized
Hey all, I'm running win 7 64bit on a P6X58D premium mobo I just build the computer and had a brand new SSD that i loaded windows onto. now none of my USB stuff will work mouse/keyboard/thumbdrives/anything none of them work, but when I plug them in windows detects them and just goes...
Hardware & Devices
