Change monitor refresh rate using 240hz monitor
  1. Posts : 68
    7
    PlayStation® 3D Display with SimulView? Technology | PS3? Accessories -PlayStation®
    I have this monitor, but when i connect it to my pc i only get 60hz as the highest option. I figured at least 120hz would be available.
  2. Posts : 2,409
    Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
    Sony hating Microsoft? Just kidding. Your video card may only support up to 60hz.
  3. Lee
    Win 7 Pro x64, VM Win XP, Win7 Pro Sandbox, Kubuntu 11
    It depends on what the graphic card can handle. . .:)
  4. Posts : 26,869
    Windows 11 Pro
    I have always been under the impression it is the monitor's refresh rate. All monitors have a refresh rate. If you were to set a 60Hz monitor to 144 Hz, you would suffer a lot of screen tearing and artifacts. The card would be sending the signal to the monitor faster than the monitor is capable handling. They make monitors with higher refresh rates. If you have one, you would see higher options.
  5. Posts : 68
    7
    ahh, im using the onboard sandy bridge card
    i will take a look at getting a new gpu card
    i actually prefer microsoft over sony lol but this is the only full hd monitor with these specs this cheap
