Windows 7: PC will not even power on with 2 gigabit NIC cards, other one does
05 Mar 2014   #1
sdowney717
The 2 NIC's that it will not even spin the fans are
Intel PRO /1000 GT
NETGEAR GA311 Gigabit Ethernet PCI Adapter support 10/ 100/ 1000Mbps
It will power on and load the os with a Realtek 8169/8110
The board is an MSI PM8M-v ms-7104 ver 2
These are PCI buss Nic's.
I noticed the Realtek does not use the last 2 pins, it is physically shorter where it fits the slot.
So why does it do that?
PC will not even power on with 2 gigabit NIC cards, other one does-rtek-2-.png
05 Mar 2014   #2
TVeblen
So there are 3 network interface adapters.
Intel PRO /1000 GT
  • Is this a PCI card, or on-the-MB NIC?
  • Will it start up with just this NIC?
Realtek 8169/8110
  • We know it will start up with this NIC.
  • Is one or the other NICs connected at the same time?
  • What combinations have you tried?
How many PCI slots do you have available on the motherboard?
Do you have any PCI-e slots? How many? What type (1x 4x 8x 16x)?
05 Mar 2014   #3
sdowney717
Filled in with answers.
Quote   Quote: Originally Posted by TVeblen View Post
Intel PRO /1000 GT
  • Is this a PCI card, or on-the-MB NIC? PCI cards all of them
  • Will it start up with just this NIC? No
Realtek 8169/8110
  • We know it will start up with this NIC. Yes
  • Is one or the other NICs connected at the same time? No
  • What combinations have you tried? all the PCI slots
How many PCI slots do you have available on the motherboard? 3
Do you have any PCI-e slots? How many? What type (1x 4x 8x 16x)? No, this is an older pentium 4 MB
Has AGP and 3 PCI slots.
05 Mar 2014   #4
sdowney717
The realtek 8169 card has shorter PCB where it plugs into the slot.
The Netgear and the Intel have two extra copper fingers at the back end of the PCB.
MB is PM8M-V ver 2, MSI 7104
The PCI version is 2.2
http://us.msi.com/product/mb/PM8MV.html
I know newer boards are PCI version 2.3
If I plug other cards, like a wireless Microsoft network card 802.11g in the slot, it works.
05 Mar 2014   #5
sdowney717
I solved it!
The PS is too weak.
I ripped another power supply out of my main PC to test.
It boots fine now with the NIC card plugged into the slot.
I sat there before changing it and the PC shut off poof!
Made me think the PS might be bad.
05 Mar 2014   #6
TVeblen
Glad you got it solved. Good thinking!
Power Req for twoXFX R9-290A Video Cards Crossfired
Looking to buy two XFX R9-290A Video cards and Crossfire them. Each has a minimum system requirement of 750Watts. My PC has a Coolmax CUG-950W power supply and has been driving two XFX HD-5770 cards for over three years. My question is; will the actual PS still be able to drive the two new...
Graphic Cards
AMD cards Vs nVidia cards? Got very confused by a thing
Hi.. So my psu got messed up so i have now sent it in and using a old psu without pci-e power so i had to change out my GTX 660 to my old ATI Radeon 4650 Though the gtx 660 kicks donkey in gaming the Radeon is running flash games smoother and some other stuff to Also a bit of a OpenCL vs CUDA war...
Graphic Cards
Article: Power Consumption of Contemporary Graphics Cards
This article will help in the endless debate about how large a power supply you need to run a gaming card. The tests show conclusively that the answer is an undeniable: "It depends"! Interesting. Enjoy. Power Consumption of Contemporary Graphics Accelerators: Spring 2010 - X-bit labs
Graphic Cards
help setting up gigabit LAN
my family just bought a new wifi router (NETGEAR N300 Wireless Gigabit Router) to replace our old one that kept loosing connections (Linksys Wifi-G, something old like that). everything works well but im having trouble setting up my PC to use its gigabit LAN function. My brother's PC automatically...
Network & Sharing
no gigabit ethernet.
Hi all. i have a gigbyte G21mx-s2 motherboard in my media center, i am on windows seven 64 bit, i have a HP pro Curve gigabit switchand a tp-link router. all my devices are hard wired through the switch and the switch is wied in to the router. the gigabyte website has no drivers for this OS...
Network & Sharing
Gigabit nic stuck at 100mbps in Gigabit network.
Cannot get gigabit performance out of Nics in Win 7.. Locked 100 mbps. My motherboard is an Evga 590 Sli Am2 motherboard, with dual gigabit nics. Having established that there is really no benefit to using both nics at the same time in another post, I am now posting because it seems I am only...
Network & Sharing
