Windows 7: SMPS fan is not running but motherboard is getting power
09 Mar 2014   #1
soaef
Windows 7 Ultimate 32 Bit
Hello
Yesterday my PC shutdown ever 2-3 Hours without any reason.
So I decided to check it what's the problem ,so I just clean the RAM shot and remove the dirt from the case.
An I try to run my PC without closing the case,So when I turn on the power ,My motherboard is getting power signal(green light ) and when I start my PC ,my CPU fan start running but my SMPS fan is not running also I an not getting any display on my screen , also my hard disk light stop working .
09 Mar 2014   #2
RogerR
7 x64 Ultimate
Quote   Quote: Originally Posted by soaef View Post
Hello
If the CPU is overheating (or failed), the system may be shutting down in self-protection. Have you been overclocking? Have you reset the motherboard settings to default?
10 Mar 2014   #3
Indianatone
Hello
Replace the power supply. The fan in the power supply will be powered by a 12 volt supply which is also needed by the hard drives, motherboard and video card.
10 Mar 2014   #4
matts6887
Windows 7 ultimate 64-bit
i agree with roger. You should probably check your cpu fan for overheating. Also, indiana is right; if the video card, etc are not getting the proper voltage; then certain fans may function poorly or in this case not at all.
SMPS Updation for Gaming
Hi... i am having Nvidia geforce 210 gpu and Solitaire 220w smps... but my smps is currently performing not well,some of its capacitors have become useless... though my gpu is running well without any problem... but i am thinking to replace my smps... i also have a wish of updating my graphics...
Gaming
8-PIN Motherboard and a 4-PIN Power Supply
I was looking through motherboards and noticed that this one has an 8-PIN power connector. I went and looked through PSUs and found that most are only 4-PIN, like this one. What am I missing? How do you connect a 4-PIN PSU to an 8-PIN board? Thanks!
General Discussion
Motherboard and CPU power restrictions
Why is it that AMD socket motherboards specify CPU power limits and Intel socket motherboards do not. (yes I did google) Edit: It's not a quiz question! It does suggest another reason for Intel to be a better option - better CPU power management. I would have expected some hardware buff to...
Hardware & Devices
No power to motherboard
OS=Windows 7 Ultimate 64 bit MB=Asus P5G41T-MLX Plus I had been on the computer for a couple of hours & then logged off to do some chores.Came back 3 or 4 hours later & turned on the comp nothing happened.Thought it might be power supply so pulled it & installed an extra I had....
General Discussion
Motherboard has power but won't power on at all?
Hey guys, I just recently built a rig and thus began my first steps into overclocking (i never overclocked my previous rig). So about 2 hours ago, I was benchmarking grand theft auto IV when my GPU suddenly ramped up to max fan speed and I lost picture on the screen. My gpu is an EVGA Geforce...
PC Custom Builds and Overclocking
new motherboard - no power up.
Hi all, i was passed a packard bell x2414 the other day as it failed to power up. The fans would spin but nothing else. ive tested the power supply using an antec power tester and get no errors so that counts out the PSU. i then came to the conclusion that it was either the motherboard or...
Hardware & Devices
