Help Required - Building a PC
Page 1 of 5 123 ... LastLast
  1. Posts : 55
    Windows 7 Professional x64 Windows 8 Professional x64
    I know I had not yet build a pc.
    But my considerations are the following-
    Processor - AMD FX 8350/Intel Core i5 3570K/ or any i5 (atleast 3rd gen)
    GPU - Nvidia GTX 760
    Motherboard - According to processor
    PSU - Corsair VS650 650 Watts
    HDD - WD Cavier Green 2TB
    RAM- Corsair Vengeance 2x8GB
    Computer Cabinet- Not yet decided
    My question is i am not able to decide which processor to take from the above and please suggest a mobo accordingly. Also a computer cabinet. I will be using my pc mainly for high end gaming and some video encoding.
    I am from India. So please don't suggest Newegg.com or any other online website.
    I prefer flipkart.com (Newegg.com brother for India)
    My budget is INR 65,000 (1060 USD)
    Please don't exceed the budget.
  2. Posts : 12,012
    I don't see any cases in stock at Flipkart.
    How much storage do you actually need? I'd rather see you get a 7200 rpm drive, but the WD Caviar Black 2 TB is 10058 versus 6046 for the 2 TB green.
    Most people can get by fine on 8 GB of RAM. What makes you think you can't?
    Do you intend to overclock?
    I'd lean toward the Intel processor, all things being equal. But you may have to compromise due to budget.
    You don't need a 650 watt PSU. I'd get a Seasonic around 500 watts.
    For $1060, I'd normally insist on an SSD for the OS at least, but they are very expensive from flipkart.
  3. Posts : 55
    I don't need an ssd. I will do with HDD. For gaming I require 16 GB but I think 12 GB will also be fine.
    I intend to overclock in the near future. Exclude cost of os. I didn't understand your rpm thing
  4. Posts : 12,012
    RPM is the revolutions per minute at which the drive platters spin.
    Faster is better for a boot drive. Green drives are 5900 rpm; Blacks are 7200; you would notice the difference, but green is OK if your budget demands it.
    To overclock the Intel processor, look at motherboards with a Z87 chipset.
  5. Posts : 2,409
    Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
    RPM stands for Revolutions Per Minute. It is how much times the drive platter (the disks) spin around fully in a minute. You are better off getting a 7200rpm drive that is NOT ecofriendly. (Note, I am not a anti-enviromentist. I'm just saying that the performance drives tend to be way faster)
  6. Posts : 2,409
    Oops we posted at same time.
  7. Posts : 2,409
    Or you can go with the blue drives which are in the middle.
  8. Posts : 55
    I think Seagate barracuda 2 tb will be best according to budget.
    I am now looking for 12 GB ram. Thanks but help me fix processor and motherboard
    Exclude os
  9. Posts : 12,012
    3570k is 16748
    Seasonic S12II PSU is 5250
    Asrock GA-Z87-Pro 3 is the cheapest overclockable motherboard I see; 10574
    Seagate Barracuda 2 TB; 6150
    add GPU, RAM, case,
  10. Posts : 55
    I think due to budget I should forget overclocking.
    Suggest a mobo for 100 USD for Intel i5 3570k.
    And one more thing
    8+4 GB ram or 4x3 GB ram?
    Suggest model also for ram at most 135 USD total for ram.
    Thanks and please reply fast.
