Windows 7: Need help finding parts for new PC build ($500 budget)
18 Mar 2014   #11
whs
Microsoft MVP
TigerDirect has a lot of bare bone kits that may be a good start. They have good prices too. It is probably cheaper to start with a bundle.
Barebone Kits | TigerDirect.com
18 Mar 2014   #12
carwiz
Windows 7 Pro-x64
I guess my adding machine is broken. That's WAY over $500. Did you include his $80 case? The OP said he has a budget.
18 Mar 2014   #13
Computer0304
Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
18 Mar 2014   #14
Computer0304
Oh forgot case. I caculated with the Gigabyte motherboard but it may be more expensve since i reccomend the ASUS one.
19 Mar 2014   #15
ReaperWarLord
i would recommend for a alright graphics card get the geforce gt 550ti GeForce GTX 560 Ti and GeForce GTX 550 Ti i think you looking at round $200 probabley cheaper in the US
19 Mar 2014   #16
HarriePateman
Windows 7 Ultimate 64-bit
Quote   Quote: Originally Posted by intelguy77 View Post
Nice!
When you say GTA, do you mean GTA 5? Or just the first one? Is it smooth at max settings?
GtA 5 isn't out on PC yet mate!
San Andreas and IV on max.
budget pc build 9 (gaming)
CPU: AMD Athlon II X4 630 Quad Core Processor MOBO + CPU Bundle = $146.99 MOBO: ECS A790GXM-AD3 Motherboard GPU: XFX Radeon HD 6850 1GB GDDR5 - miniDP, HDMI, DVI - $189.99 RAM: Patriot Signature PC10600 4GB DDR3 Memory Upgrade - $69.99 Hard Drive: Samsung HD103SJ Spinpoint F3 Hard Drive - 1TB,...
PC Custom Builds and Overclocking
Budget Gaming Build
This build will also be used for Homework,Skype, For now Minecraft(Better games after buying the graphics card) and internet browsing please feedback on the parts and components CPU - AMD Fx-6300 - 111.96 Motherboard - Gigabyte GA-970A-DS3 - 52.76 RAM - Corsair Memory XMS3 8GB DDR3...
I need help finding parts (capacitors) for a monitor.
I have contacted HP. They say they can't help with this. I need to find out what capacitors fit my HP 2509b monitor. My monitor is flickering and I would like to replace the bad capacitors. I would like to know what possible capacitors are inside of the monitor and order them bad or not. They...
Hardware & Devices
Help on an Intel $800-$900 budget build
Hi all, I am planning to build a general-purpose PC with a budget around $850AUD, but I could go over if necessary. It will be used for programming, a bit of gaming, schoolwork and Internet. I will choose Intel. Parts so far: CPU - 2500k - $218.00 Motherboard - Asrock Z68-Extreme 4 LGA1155 -...
Need help finding parts for computer I'm building
Here are the parts I am working with (parts I bought and will be using in my new PC). Graphics card (EVGA GeForce 9800 GTX+) - http://www.newegg.co...N82E16814130339 Memory (OCZ 4GB (2 x 2GB) DDR2 SDRAM) - http://www.newegg.co...N82E16820227248 Power supply (Ultra LSP750 750 Watts) -...
Hardware & Devices
Possible budget gaming PC build?
Hi I am trying to build an Intel budget gaming PC for the first time. I have a budget of AUD$1000 and have come up with this so far (price is AUD at my local parts store): CPU - Intel Core i5 760 LGA1156 CPU - $211.00 MOBO - Gigabyte GA-P55-USB3 P55 MB - $159.00 RAM - 4Gb DDR3 1333Mhz...
