Windows 7: Need help finding parts for new PC build ($500 budget)
18 Mar 2014   #1
intelguy77
Windows XP 32bit
I figured I might as well come to the experts here at SevenForums for some guidance and support on finding parts for my new PC build. I'm working with a budget of $500. I've looked at Newegg and Amazon, trying to find the best deals, but I'm pretty lost as to what grounds to start on. I'd like to be able to run Windows 7 64-bit and play recent games like Diablo III and DotA 2 at max or recommended settings with no issues. I am excluding monitor, sound system, keyboard, and mouse from this build because I already have each of those items.
So, can someone help me find parts at a good price? :-) So far I only know what case I want, which is this one here:
COUGAR Orange Challenger Black Steel ATX Computer Case with 12cm COUGAR TURBINE HYPER-SPIN Bearing Silent Fans and 20cm LED Fan - Newegg.com
I still need: Mother board, HDD, PSU, Graphics card, Processor, RAM... Am I missing anything else? I think that's it.
18 Mar 2014   #2
HarriePateman
Windows 7 Ultimate 64-bit
I currently use a gigabyte H87-HD3 motherboard. Its really good.
Dual bios (UEFI)
USB 3
all the bells and whistles! :P
Good value as well 67
18 Mar 2014   #3
mjf
Windows 7x64 Home Premium SP1
Quote   Quote: Originally Posted by intelguy77 View Post
The operating system. OEM ~$100.
18 Mar 2014   #4
intelguy77
Windows XP 32bit
Quote   Quote: Originally Posted by Harribo2014 View Post
Dual bios (UEFI)
USB 3
Cool mother board. Found it on Newegg. It's got mixed reviews though. What GPU are you using with that board?
Quote   Quote: Originally Posted by mjf View Post
I have the operating system already. Sorry, forgot to add that to the exclusion list.
18 Mar 2014   #5
HarriePateman
At the moment i'm just using integrated Intel HD3200 Graphics. Finished my build last week and realized i was short on money. So the GPU will have to wait until next month. But to be honest im not a big game player. And the integrated graphics are okay for me, i can play GTA on full, and Euro truck simulator!
18 Mar 2014   #6
intelguy77
Windows XP 32bit
Nice!
When you say GTA, do you mean GTA 5? Or just the first one? Is it smooth at max settings?
18 Mar 2014   #7
Computer0304
Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
18 Mar 2014   #8
carwiz
Windows 7 Pro-x64
Are you really picking the case first on a $500 budget?
It's what goes into it that counts. Half or more of your budget will be blown on a GPU. That leaves room for an AMD on a decent board and a good power supply. Throw in a SSD for the system and scrounge a HDD for files. What's left may buy a cheap box and can of spray paint. Set your priorities where it counts the most for your use. Glamor shouldn't be one of them.
18 Mar 2014   #9
carwiz
Windows 7 Pro-x64
18 Mar 2014   #10
Computer0304
budget pc build 9 (gaming)
CPU: AMD Athlon II X4 630 Quad Core Processor MOBO + CPU Bundle = $146.99 MOBO: ECS A790GXM-AD3 Motherboard GPU: XFX Radeon HD 6850 1GB GDDR5 - miniDP, HDMI, DVI - $189.99 RAM: Patriot Signature PC10600 4GB DDR3 Memory Upgrade - $69.99 Hard Drive: Samsung HD103SJ Spinpoint F3 Hard Drive - 1TB,...
PC Custom Builds and Overclocking
Budget Gaming Build
This build will also be used for Homework,Skype, For now Minecraft(Better games after buying the graphics card) and internet browsing please feedback on the parts and components CPU - AMD Fx-6300 - 111.96 Motherboard - Gigabyte GA-970A-DS3 - 52.76 RAM - Corsair Memory XMS3 8GB DDR3...
I need help finding parts (capacitors) for a monitor.
I have contacted HP. They say they can't help with this. I need to find out what capacitors fit my HP 2509b monitor. My monitor is flickering and I would like to replace the bad capacitors. I would like to know what possible capacitors are inside of the monitor and order them bad or not. They...
Hardware & Devices
Help on an Intel $800-$900 budget build
Hi all, I am planning to build a general-purpose PC with a budget around $850AUD, but I could go over if necessary. It will be used for programming, a bit of gaming, schoolwork and Internet. I will choose Intel. Parts so far: CPU - 2500k - $218.00 Motherboard - Asrock Z68-Extreme 4 LGA1155 -...
Need help finding parts for computer I'm building
Here are the parts I am working with (parts I bought and will be using in my new PC). Graphics card (EVGA GeForce 9800 GTX+) - http://www.newegg.co...N82E16814130339 Memory (OCZ 4GB (2 x 2GB) DDR2 SDRAM) - http://www.newegg.co...N82E16820227248 Power supply (Ultra LSP750 750 Watts) -...
Hardware & Devices
Possible budget gaming PC build?
Hi I am trying to build an Intel budget gaming PC for the first time. I have a budget of AUD$1000 and have come up with this so far (price is AUD at my local parts store): CPU - Intel Core i5 760 LGA1156 CPU - $211.00 MOBO - Gigabyte GA-P55-USB3 P55 MB - $159.00 RAM - 4Gb DDR3 1333Mhz...
