Windows 7: Problems connecting using westinghouse hd tv monitor
26 Mar 2014   #1
Capin Jimmy
Windows 7 Professional 32-Bit and Windows 7 Professional 64-Bit
Hello I have a Westinghouse LCD-TV with HDMI output model SK-19H210S. Im trying to connect it to my copumter via HDMI but my computer never sees it. I know the monitor works because i used the vga port to connect to my old laptop running Windows Xp. Any helpwould be much appreciated. Thanks.
27 Mar 2014   #2
Ranger4
Open Control Panel, select Devices & Printers & when that opens, you will see Add a Device up in the left hand top corner, click on that & Windows will do a search for new devices. Hopefully that will find your TV monitor.
Make sure you have it properly connected first.
Westinghouse L2610NW will not work with HDMI/DVI cable
Gateway FX6800 computer was purchased in August and everything has been perfect with pre-loaded Vista Home Premium 64bit. Westinghouse 26" L2610NW monitor installed with HDMI to HDMI/DVI cable on a single ATI HD 4850 GPU. Fast forward to Oct 22nd when I finally was able to install Windows 7...
Graphic Cards
Connecting a second monitor
Hi, Can anyone help me with connecting a second monitor to my first? Also what cable will I need and is there any configuring to do when 2 screens in operation. I want to finish a a wordpress website on one monitor but have instructions/ tools shown on second monitor? thanks.
Graphic Cards
Problems connecting with Monitor
I have asus g74sx, it has Nvidia Geforce GTX 560M video card. I've recently bought the Benq XL2410T LCD monitor. When I first started it, it was working great. I was able to use DVI to run my games in 3d. I restarted my computer and now DVI works on start up, and will show the screen briefly if...
Graphic Cards
connecting PS3 to monitor?
Hi all, I have an AOC 936swa LCD monitor and want to try and run my PS3 through it. The input into the monitor is via D-Sub and USB. I made the schoolboy error of thinking it was a DVI and buying an HDMI to DVI cable...face-to-palm moment there! Is there an HDMI to D-Sub cable? I can't...
Hardware & Devices
Connecting Monitor To Card
I just got my first graphics card and i have to ask a really nooby question... The card didn't come with a dvi vga adapter and do i need one to use the graphics card with the monitor?
Graphic Cards
Thought about something : Connecting a Wii to Monitor
Sp, this morning, when I woke up, I thought about this. I would love to play my friend's Wii on my monitor. But the thing is, as most of you know, that the Wii only give video output via composite. My monitor (my current one) has a DVI and VGA inputs. I'm currently using the DVI one. So, I...
Chillout Room
