Windows 7: Need help solving loud fan issue
08 Apr 2014   #1
stnewlon413
Windows 7 Home 64
So this problem started a few months ago when I tried playing a PC game on my computer. All of a sudden, one of the fans inside the PC starting going CRAZY. Like, REALLY loud. I turned off the game, and everything went back to normal. no noise. I tried it again when Elder Scrolls Online came out, and the fan is going insane again. I turn the game off and I get no noise.
I'm fairly certain it's my graphics card that is making the noise, but I also wanted to be safe and reapply thermal paste to my cpu fan just to make sure. Is there any way to quiet down the graphics card so I can play my games in peace and quiet? Or is this something I'm going to have to live with?
08 Apr 2014   #2
Mellon Head
Do you have fans blowing into and out of your case? More air circulation means that the GPU fan has to work less hard to keep the GPU cooler.
08 Apr 2014   #3
ignatzatsonic
Quote   Quote: Originally Posted by stnewlon413 View Post
Don't be fairly certain. Be absolutely certain. Do that however you can, possibly by physically stopping various fans for one second by hand to see if the noise disappears. Get your head inside the case.
Have you checked CPU temps with a temp monitoring application? Unless CPU temps are excessive, I'd seriously doubt any re-application of thermal paste to the CPU will have any effect.
If the noise from your graphics card fan is in fact the cause of the noise, that fan may be failing outright and require replacement--particularly if that game didn't cause fan noise previously.
08 Apr 2014   #4
Boozad
It could well be the PSU as it's being put under load. As mentioned above, make sure you know exactly which can it is first and foremost.
Event Viewer Problem solving
Hello, I just finished talking to a technician and he took over my computer and found out the reason why it would not start up properly and why it was slow and crashing. Unfortunatlely since i am only 17 i could not afford to pay 130$ for him to fix it. From what i saw while he was trying to find...
Performance & Maintenance
Need some help solving my BSOD issues
Hey there, need some help fixing my BSOD issue on my Dell Inspiron 1564 laptop. I've had this problem for a few months now and it's getting pretty irritating. I'm almost certain it's down to a corrupted driver/s (since the blue screen describes a BUG_CODE_USB_DRIVER) but I'm no expert so was...
BSOD Help and Support
Need help solving dump and crash problem
In November I built a new system which was running well aside from some minor graphics driver hiccups. Over the last few months though I've been experiencing many dumps and reboots caused by a number of processes and applications. Sometimes A BSOD will show, sometimes everything just freezes and...
Solving problems...
How does a topic/thread get marked as solved?
General Discussion
To Mods -- to help solving peoples problems
Hi there Suggestion for the Mods With so many builds and X-86/X-64 versions I suggest that people should always now state what build and what version they are using. It doesn't help people to suggest an answer or even find one if you look at a post which just says "I've just...
Chillout Room
