Windows 7: Laptop Cooling Vent (Not Fan) issue
09 Apr 2014   #1
SimpkinX
Hi!
My laptop Cooling Vent gets surprisingly hot after a while, but I don't know why, my laptop is a Samsung make and it does not have a cooling fan, it just holds a vent. What feels worse is that the plastic where I believe the fan is or graphics card is becomes extremely hot, an example would be that the VGA port metal casing becomes untouchable due to the heat.
Please help?
09 Apr 2014   #2
Layback Bear
Windows 7 Pro. 64/SP-1
We need specs of your laptop and also your desktop.
By Brink:
System Info - See Your System Specs
By Kari:
Speccy - Publish Snapshot of your System Specs
09 Apr 2014   #3
SimpkinX
System Specs have been added to my profile
09 Apr 2014   #4
Layback Bear
In your specs it states (PC) but the specs indicate Laptop.
Could your give us the model number so we can look things up.
My concern is you state you don't have a cooling fan.
Have you monitored your CPU and GPU temps? If so what is the high temps?
I have no idea what this means.
How long has it been sense the laptop has had a good internal cleaning?
post # 1.
09 Apr 2014   #5
SimpkinX
Thats correct, it doesn't have a fan as a normal fan, I can't find it, but It still ventilates.
Model Number : 300E4A/300E5A/300E7A/3430EA/3530EA
09 Apr 2014   #6
Layback Bear
Thank you.
It's a Notebook without a fan.
They do make cooling pads and add on external fans for cooling.
Try again; what temps are the CPU and GPU when the vents are hot.
Calling my Notebook repair shop and reading on line their isn't much you can do without adding external cooling.
Now that we know it's a Notebook hang around and lets see if someone drops by that uses Notebooks.
Sorry but I find no other information to be able to help more.
This will be helpful for the temps.
http://www.piriform.com/speccy
10 Apr 2014   #7
TVeblen
It looks like there is a fan in the 300 series notebook:
Aliexpress.com : Buy NEW FOR Samsung 300E4A (NP300E4A) Cooling Fan MF75090V1 C090 G99 from Reliable fan unit suppliers on Online Store 939007
Laptop Fan For Samsung 300e4a Dfs531005mc0t Fb06 Ba31-00107b Dc5v 0.50a [FS300E4A-1] - $7.50 : www.cdrtd.com Wholesale Laptop Accessories
Most likely you need a good cleaning. Do you feel air blowing out of the side vent?
The test for proper ventilation:
Cut a 1 inch square of single ply facial tissue paper or toilet paper. With the notebook on, and holding it up so the bottom of the notebook is vertical, place the tissue paper over the vent holes on the bottom of the notebook (Note: some laptops draw air for a vent on the side, or even the back). If the tissue sticks you have good ventilation. If it slides off there is poor ventilation.
10 Apr 2014   #8
madcratebuilder
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
What TV sai9d, replacement fan. Spendy little devil.
cooling pad for my laptop?
hello i have a dell studio 14" laptop that i use for gaming and such. im planning on getting a new graphics card, and overclocking, so i will need a little more cooling. i have a cooling pad now, but its 2 small fans that actually dont do much because the fans are only pointed on the case, not on...
Chillout Room
laptop cooling related
hello i wanna know how much a cooler can reduce the temperature of laptop.. another think i noticed that just a simple multi tabbed browsing my dell 15R laptop (core i5) temperature is up by 50-55 C..does it natural ??:eek: waiting for your replies
General Discussion
about laptop cooling
hello guys i just bought dell inspiration laptop if i use laptop 4-5 hrs does laptop need additional cooler ?? however i bought a cooler but sometimes when try to turn off laptop with cooler plug in laptop hang n don't shut down it's making me worried :cry: need your help
General Discussion
Laptop Cooling
I need your opinion! König USB 2.0 Notebook Cooling Pad, COOLER101 - Computer.is vs. Start tölvuverslun - start.is It has english information also. I got 15" Toshiba laptop.
Chillout Room
Cooling down a laptop help
This may be REALLY dumb but how do you control the temperature of a laptop cause my laptop has been shutting down automatically while playing games. I think its a bit overheated.
Gaming
Laptop Cooling Fan
Does anyone know of or used any good laptop cooling fans? I want one top of the line, but I don't know what top of the line is.
Hardware & Devices
