Windows 7: Non-PWM Fan on a PWM Fan Header
21 Apr 2014   #1
Lady Fitzgerald
Win 7 Ultimate 64 bit
Is it possible to run a 12v fan (3 pin non-PWM) on a MOBO PWM fan header (4 pin)? If so, will it just run at full speed only or would I be able to control the speed somewhat?
21 Apr 2014   #2
ignatzatsonic
In my experience, it should run on some or other of the 4 pins--at full speed. Fans always take some fiddling and experimentation.
21 Apr 2014   #3
NoN
No...I've got Two of my 3pins Pc case 12v fans plugged in the motherboard 4pins PWM and they still available in the monitoring speed software. I can easily set parameters speed on them.
21 Apr 2014   #4
Lady Fitzgerald
Quote   Quote: Originally Posted by NoN View Post
"Curiouser and curiouser," said Jeannie (apologies to Charles Lutwidge Dodgson), especially since my MOBO uses the same software (AI Suite II). This is good to know. Thanks!
21 Apr 2014   #5
crawfish
You Asus users might find this thread interesting:
ASUS Z87-Deluxe fake 4-pin headers & other fan control info
21 Apr 2014   #6
NoN
Quote   Quote: Originally Posted by crawfish View Post
Humm...my mobo have 4 headers with 4pins. I can plug two of 4 pins PWM fans (CPU_Fan & Cha_Fan) and still have the speed control in Bios (set to manual setting) & set my testing parameters in Ai Suite II software.
The two others 3 pins PC Case are also set "manual" in Bios according my demand to reflect them in AI Suite II software.
Since I can control the low/mid/high RPM percentage according to the CPU Temp and test the fans speed with Fan Xpert+, i don't see any issues in that right now.
Thanks for the link, might dig that a bit!
On screenshot it shows % w/Temp regulation for a 3 pins Fan plug on 4 pins header.
22 Apr 2014   #7
Lady Fitzgerald
I have a P9X79 WS (as in Work Station) MOBO. I took a look at my manual (yeah, I actually keep it handy and use it) and all four of the chassis fan headers show the following connections:
CHA FAN PWM
CHA FAN IN
CHA FAN PWR
GND
Nothing is mentioned about any voltage, let alone +5v. There are no little switches by the headers either. Methinks my MOBO actually does support true PWM (after what I paid for it, it bloody well better!).
22 Apr 2014   #8
NoN
Quote   Quote: Originally Posted by Lady Fitzgerald View Post
CHA FAN PWM
CHA FAN IN
CHA FAN PWR
GND
Screenshot shows mine either...
22 Apr 2014   #9
crawfish
FWIW, my two 3-pin case fans are attached to 4-pin headers on my Asus Gryphon Z87 which has the "fake" PWM chassis fan headers, and the BIOS controls the speed, while AI Suite III provides finer control inside Windows. I've set them to idle around 480 RPM, while the CPU fan (true PWM) idles at 200 RPM. They all ramp up with CPU temp. Works great. Per that thread I linked to, PWM fans attached to the fake headers are still controllable to some extent, and it's subtle to determine from their behavior if you're getting "real" PWM.
To the OP, YMMV with other motherboards and software.
22 Apr 2014   #10
NoN
Might some 3pins fans got RPM Signal and very basic ones don't. But i do think when using 4pins PWM on those described headers its still be kind of PWM as schema shows it. Yes, Q_Fan for CHA_FAN in bios have slight different setting than the CPU_Fan.
Bsod bad pool header
Hi I get a BSOD everytime I try to plug in the new monitor I purchased. The monitor is a Yamakasi Catleap 2703. If you need any other information let me know. Thanks for your help. Mitch
BSOD Help and Support
USB 3.0 Front Panel Header
I have a Corsair case with an Asus P8Z77 LX motherboard. I have already had Corsair send me a replacement front panel connection for the USB 3.0 ports, and am now stuck at what to do. Basically USB 2.0 connection speeds are abysmal over the front panel USB 3.0 ports. USB 3.0 (Hard disk and...
Hardware & Devices
How do I edit a thread header?
I posted a query in the Crashes and Debugging section, but I want to change the header text, as it seems to be scaring people away. I am able to edit the main text of the thread but not the header itself. Does anybody know how I can do this?
General Discussion
Margin below a header
Hi all, In my official business document I use a header, which is my company logo. With text I can simply "return" a couple of times at the start of a page and I will create a nice margin below the header. But when I use a table (which I do in most of my documents) and it crosses over to...
Microsoft Office
Bad Pool Header
I get alot of BCOD. I did a new new install of windows 7
Seven Forums Header
Didn't really know where to put this, so I figured off topic will do. (hopefully some Admin will come by) I don't quite understand the header for this site... The search bar is an image that links to a search page. In terms of web development, this does not make any sense. Surely it can't be too...
Chillout Room
