Windows 7: Mouse double clicks when I click once and click when I hold it.
04 May 2014   #1
shippou
windows 7 ultimate x64
What I mean is that let's say I am trying to hold and drag a desktop file it will sometimes just click, making me drop the file on the spot. It will also double click when I try to make a single click. I tried to lower the settings for double click timing on the settings menu.
EDIT: Tried out another mouse, it doesn't click out of nowhere but is there a way to fix my old mouse? I can switch the buttons so right click acts as left click so it seems that specific button got practically destroyed
04 May 2014   #2
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Do you mean the other mouse works fine? As far as I know there's no way to fix a mouse other than making sure the trackball or optical lens is clean, whichever your has.
A repair would cost more than a new mouse I suspect. You can get an ordinary one for about $5 or so.
05 May 2014   #3
shippou
The other mouse worked just fine but now the old(broken?) mouse works again. How is it even possible for a mouse to periodically click on it's own and fix itself given time?
05 May 2014   #4
Britton30
Microsoft MVP
Bad cable, LED, or electronic snafu. It'll likely quit working again.
05 May 2014   #5
shippou
Good night sweet mouse.
Thanks for the help
08 Jul 2016   #6
dogeroll24
Windows 10 Home 64x
I have a temporary fix for anyone who doesn't want to fix their mouse or buy a new one!
Go to: www.clickfix.cf
It takes less than 5 minutes to set up, guaranteed (by me anyway )
Mouse is double clicking with only a single click.
I just done the latest windows update today, it has been sittin there since last week but I havent turned off me PC since it downloaded. Anyway, since I have done it the mouse is double clicking with only a single click. Also it hard to highlight text and stuff with it as it keep selecting...
Hardware & Devices
Mouse/Trackpad registering one click as hold/drag
My computer, which is a Toshiba C655, thinks I am holding the primary mouse button down, when I've just simply clicked. I don't have Click Lock on, I've tried using my bamboo tablet, and the problem persists. I've also tried a reboot, but that didn't work either. If anyone can give me a solution,...
Hardware & Devices
Mouse double clicks when i single click
Hey all, I got this rather annoying problem lately. As title says, my mouse seems to double click when I just clicked once. You can notice that in browsers, when I click on an address in the suggestions, but the click "goes through" and clicks on a bookmark behind the drop down menu which vanished...
General Discussion
Mouse Double-clicking on Single-click
I have a wired 5-button Microsoft optical Intellimouse, about 5 yrs old. Lately it's double-clicking when I single-click, which obviously is quite annoying. It's not the software mouse clicking speed, that doesn't solve it. I switched to an old mouse temporarily and the problem didn't occur, so...
Hardware & Devices
Mouse double clicks when i singe click
when i single click my mouse will be picky, its a 120 dollar mouse so it shouldnt be this picky, i have been noticing lately that my os has been being effected by games and programs like audacity, i change mic volume, it changes my mic volume PERMINANTLY, i change speaker volume, same thing, i have...
Hardware & Devices
My mouse doesn't Double click anymore.
I seem to have a problem, it keeps happening all the time with my Laptop. 4 times I have reinstalled to get rid of this error, and it has happened a 5th time! I log on and my mouse speed is slow and double click is disabled! I looked around in mouse settings and it doesn't show anything about...
Software
