Windows 7: USB Intermittent Drop Out - Not Power Related
14 May 2014   #11
floateruk
Windows 7 64 bit
Same error just happened through the DJ controller on the USB 3 port. I was hoping it was just a USB 2 issue.... I'd be thinking it was an issue with the controller if I wasn't having problems with my Razor mouse too.
14 May 2014   #12
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Did you use MBAM or Adwcleaner to get rid of these?
Registry Keys: 8
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\CLSID\{4e1dfdc4-5474-47fc-bcaa-6f1f0c49bae2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\CLASSES\TYPELIB\{ade2113b-9952-46c8-85b0-b115be39a9fa}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\INTERFACE\{77bf05d1-5f5f-40d2-8feb-7e326c73a257}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\TYPELIB\{ade2113b-9952-46c8-85b0-b115be39a9fa}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\EXPLORER\BROWSER HELPER OBJECTS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\SETTINGS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\STATS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\c20771cf-b330-43f0-bd27-e728ae7fe413, , [242ca3aef982aa8ce817027aaa587987],
Registry Values: 1
PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MOZILLA\FIREFOX\EXTENSIONS|{591f9d2f-ffb2-4bbe-98fc-2fb86649c789}, C:\Program Files (x86)\PassShow-soft\157.xpi, , [8bc55ef36714db5b38d8bdc6877ba858]
Registry Data: 0
(No malicious items detected)
Folders: 1
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft, , [242ca3aef982aa8ce817027aaa587987],
Files: 9
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.dll, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, C:\Windows\Tasks\PassShow Update.job, , [b29e7dd49ae1d95da29eecad986a36ca],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.dat, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.xpi, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\a.db, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\b.db, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\PsUP.exe, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\Sqlite3.dll, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\Uninstall.exe, , [242ca3aef982aa8ce817027aaa587987],
14 May 2014   #13
floateruk
Windows 7 64 bit
MBAW. I used that first and thats the program that brought them up.
14 May 2014   #14
Britton30
Microsoft MVP
You might run Adwcleaner with the Clean option, they still show up in there.
14 May 2014   #15
ICIT2LOL
Quote   Quote: Originally Posted by Britton30 View Post
that and if this doesn't get anywhere what do you reckon doing a run with the Emsisoft Emergency Kit? Emsisoft Free Emergency Kit: portable malware scanner | Free removal of Viruses,Bots, Spyware, Keyloggers and Trojans I just run the first two scanners usually.
14 May 2014   #16
Britton30
Microsoft MVP
There's also this which is good.
Free Virus Scan | Online Virus Scanner from ESET
14 May 2014   #17
ICIT2LOL
Yep well if it is gets to it then this might be worth a run
Download Kaspersky Rescue Disk 10
it will need a bootable disk to be made but at least it will scan from ground zero just about - see this What is Kaspersky Rescue Disk 10? . But it is a rather drastic step to take though.
14 May 2014   #18
Britton30
Microsoft MVP
Isn't the KIS Rescue Disk for a non-booting system?
14 May 2014   #19
ICIT2LOL
By non booting system I take it you mean it has an OS on it but will not boot to it whatever that OS is. I have tried it on both a non booter - one with Windows already on it but is not booting to Windows, and one that is booting to Windows (with problems) and it worked both times .
I am just under the impression that as long as you can set the BIOS to what boot format the rescue software is on - it will boot and scour the system from the every beginning.
But I stand to be corrected
15 May 2014   #20
floateruk
Windows 7 64 bit
So are we thinking this is a virus, or is this just to eliminate the possibility?
Would be worth getting Ubuntu onto a USB, booting from that, and testing the mouse with it in there?
intermittent failure of screen saver and power settings.
intermittent failure of screen saver and power off to activate? Hi. My Win 7 Desktop computer, unlike my laptop and other Win 7 computers, has a power and screen saver setup that, at times, never activates? I have checked background processes and can't understand why at times it kicks in and...
Performance & Maintenance
Intermittent Driver Power State Failure event id 41 in Firefox
I have had this 4 time, three within the last week. Dell diagnostics have run with no errors in hardware, ram, or hard drive. No excessive or unusual temperatures noted in I8kfangui. Running updated W7pro Is there anything obvious from my attached zip file? Please let me know what else I...
BSOD Help and Support
Intermittent HP dv7 power problem
HP laptop dv7 almost two years old. Still under hardware waranty. In the past two months I had this problem. I don't happen all the time. Three times to be exact. Laptop will not turn on when I press the power button after shut down. Battery is fully charged. The only way I can turn laptop on...
Hardware & Devices
Intermittent power off
Over the past 2 years my PC has been afflicted with random power off/power on/reboot events. It will go for months without these and then have multiples of the events in a day. (I had 8 of them 3 days ago.) I assume I have a hardware problem, but nothing has been found and I'm grasping at...
BSOD causing intermittent power to monitor on boot
Hi, Firstly, thanks for all the experts here, i have found some very valuable information! OS: Windows 7 Home Premium x64 i7-2600K CPU @ 3.40 Ghz OEM 8Gb RAM Asus P8P67Pro Harware & software build around 6 months old
Intermittent BSOD - BCCode: fe USB Related Error
I am getting an intermittent system lockup sometimes resulting in a BSOD or sometimes a system freeze, e.g. display freezes with no response from the mouse or keyboard. The errors can occur several times a day or it can be a number of days between errors. It is very unpredictable and does not...
