Windows 7: USB Intermittent Drop Out - Not Power Related
15 May 2014   #21
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
An infection may not be causing the USB issue, but you do have some infections. run the Adwcleaner in Clean function and post the log from it.
Testing with a Linux Live CD would be an option.
15 May 2014   #22
ICIT2LOL
Quote   Quote: Originally Posted by floateruk View Post
So are we thinking this is a virus, or is this just to eliminate the possibility?
Would be worth getting Ubuntu onto a USB, booting from that, and testing the mouse with it in there?
Anything is possible now mate so go ahead and run what Britton has suggested and if you like try the Ubuntu at least you will see if the cursor etc works.
intermittent failure of screen saver and power settings.
intermittent failure of screen saver and power off to activate? Hi. My Win 7 Desktop computer, unlike my laptop and other Win 7 computers, has a power and screen saver setup that, at times, never activates? I have checked background processes and can't understand why at times it kicks in and...
Performance & Maintenance
Intermittent Driver Power State Failure event id 41 in Firefox
I have had this 4 time, three within the last week. Dell diagnostics have run with no errors in hardware, ram, or hard drive. No excessive or unusual temperatures noted in I8kfangui. Running updated W7pro Is there anything obvious from my attached zip file? Please let me know what else I...
BSOD Help and Support
Intermittent HP dv7 power problem
HP laptop dv7 almost two years old. Still under hardware waranty. In the past two months I had this problem. I don't happen all the time. Three times to be exact. Laptop will not turn on when I press the power button after shut down. Battery is fully charged. The only way I can turn laptop on...
Hardware & Devices
Intermittent power off
Over the past 2 years my PC has been afflicted with random power off/power on/reboot events. It will go for months without these and then have multiples of the events in a day. (I had 8 of them 3 days ago.) I assume I have a hardware problem, but nothing has been found and I'm grasping at...
BSOD causing intermittent power to monitor on boot
Hi, Firstly, thanks for all the experts here, i have found some very valuable information! OS: Windows 7 Home Premium x64 i7-2600K CPU @ 3.40 Ghz OEM 8Gb RAM Asus P8P67Pro Harware & software build around 6 months old
Intermittent BSOD - BCCode: fe USB Related Error
I am getting an intermittent system lockup sometimes resulting in a BSOD or sometimes a system freeze, e.g. display freezes with no response from the mouse or keyboard. The errors can occur several times a day or it can be a number of days between errors. It is very unpredictable and does not...
