Windows 7: USB Intermittent Drop Out - Not Power Related
08 May 2014   #1
floateruk
Windows 7 64 bit
Hi all,
I found this forum looking for an answer to my USBs randomly cutting out, so I apologise my first post is a cry for help.
I have a Samsung np530u3c-a01uk series 5 laptop running windows 7 64 bit.
The problem I'm having is with the USB ports. I have 2 USB 2.0 ports and one USB 3.0 port. I have noticed that when turning on the laptop it can take up to a minute for a usb mouse to be recognised, and once recognised it will randomly lose connection and regain connection. More annoying for my self is that I also dj from my laptop, and I use a Behringer MM-1 which has in it a powered USB hub. After half an hour or so's use this also stops working. What is bizarre though is that all the lights on the dj controller still light up AND the sound card that is plugged into the 4 port hub on the back of the controller continues to provide sound to my amp, BUT the controller no longer gives any signals/commands to the computer until I unplug it, close my dj software, and plug the controller back in.
I have read that a lot of USB issues are around power, but clearly using only one usb mouse, or a controller with a hub and it's own power supply should cause any drain on the usb ports. I have also gone into device manager and unticked the power saving option under "usb generic hub" AND under the power options in control panel, I have disabled the USB power management options. Neither of these workarounds has helped.
I am currently using the USB 3.0 port and for 5 minutes at least, there has been no cut out with the mouse (unfortunately I haven't got the USB hub/dj controller here to test).
So.... Am I left with two duff USB ports? If I uninstall "generic USB hub" from device manager, will it just reinstall without issue? Is it worth doing? Any other ideas?
Any help would be great. Many thanks for reading.
08 May 2014   #2
ICIT2LOL
Hello an welcome floateruk mate I would be running these first
http://www.sevenforums.com/tutorials/433-disk-check.html
Then maybe update the drivers just for elimination purposes the chipset and the USB 3.0 ones
SAMSUNG
If here is no change to the machine after run these as well
http://www.superantispyware.com/
http://www.malwarebytes.org/products/malwarebytes_free/
http://www.bleepingcomputer.com/download/adwcleaner/
download from bleeping computer delete any rubbishthese find.
09 May 2014   #3
floateruk
Windows 7 64 bit
Thanks for coming back so quickly! I'm just at work but when I get back I'll give it a shot.
I also found this post on here when I was mooching last night: USB Driver - General Fix for Problems
I might try that out too.
Again, thanks for coming back to me, and I'll post what I find later tonight.
EDIT: I have already updates the chipset and USB 3 drivers. Can't see an upgrade to the Generic USB hub drivers though.
09 May 2014   #4
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
You can try uninstalling Generic USB hub and deleting Drivers too. Upon reboot manually dun Windows Update and you should get them back.
Running through the steps in the tutorial you found fixes many USB problems.
It could also be a power issue, if the port you have the self-powered hub plugged into loses its power the hub won't work.
09 May 2014   #5
floateruk
Windows 7 64 bit
I've run chkdsk and scannow and no issues.
I'm going to try the USB tutorial next and see if that clears it. If not could it really be a power issue? I guess on a laptop there's no cure but a new laptop??? That would suck.
10 May 2014   #6
ICIT2LOL
No mate just test the adaptor for volts even and also check out the battery. You could even try it with the battery out and on the adaptor alone.
did you run those malware scans and if not try them and thee is this Free Anti-Malware Download | Emsisoft Anti-Malware, Online Armor Firewall, Mamutu Behavior Blocker try the first and second scanners.
Plus it might be worth running this Download Kaspersky Rescue Disk 10 make a bootable disk and run it from power on. It doesn't take long and at least we can eliminate these things.
14 May 2014   #7
floateruk
Windows 7 64 bit
Done without issue and didn't fix problem
Disk Check
SUPERAntiSpyware | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware!
I have AVG running and it hasn't picked anything up....
Malwarebytes | Free Anti-Malware Detection & Removal Software
Malwarebytes Anti-Malware
Malwarebytes | Free Anti-Malware & Internet Security Software
Scan Date: 14/05/2014
Scan Time: 20:04:48
Logfile:
Administrator: Yes
Version: 2.00.1.1004
Malware Database: v2014.05.14.08
Rootkit Database: v2014.03.27.01
License: Free
Malware Protection: Disabled
Malicious Website Protection: Disabled
Chameleon: Disabled
OS: Windows 7 Service Pack 1
CPU: x64
File System: NTFS
User: Floateruk
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 274229
Time Elapsed: 11 min, 14 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Shuriken: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
(No malicious items detected)
Modules: 0
Registry Keys: 8
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\CLSID\{4e1dfdc4-5474-47fc-bcaa-6f1f0c49bae2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\CLASSES\TYPELIB\{ade2113b-9952-46c8-85b0-b115be39a9fa}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\INTERFACE\{77bf05d1-5f5f-40d2-8feb-7e326c73a257}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\TYPELIB\{ade2113b-9952-46c8-85b0-b115be39a9fa}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\EXPLORER\BROWSER HELPER OBJECTS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\SETTINGS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\STATS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\c20771cf-b330-43f0-bd27-e728ae7fe413, , [242ca3aef982aa8ce817027aaa587987],
Registry Values: 1
PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MOZILLA\FIREFOX\EXTENSIONS|{591f9d2f-ffb2-4bbe-98fc-2fb86649c789}, C:\Program Files (x86)\PassShow-soft\157.xpi, , [8bc55ef36714db5b38d8bdc6877ba858]
Registry Data: 0
Folders: 1
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft, , [242ca3aef982aa8ce817027aaa587987],
Files: 9
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.dll, , [321edc7590ebb383adad7aaacc368779],
PUP.Optional.PassShow.A, C:\Windows\Tasks\PassShow Update.job, , [b29e7dd49ae1d95da29eecad986a36ca],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.dat, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.xpi, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\a.db, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\b.db, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\PsUP.exe, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\Sqlite3.dll, , [242ca3aef982aa8ce817027aaa587987],
PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\Uninstall.exe, , [242ca3aef982aa8ce817027aaa587987],
Physical Sectors: 0
(end)
AdwCleaner Download
# AdwCleaner v3.208 - Report created 14/05/2014 at 20:15:15
# Updated 11/05/2014 by Xplode
# Operating System : Windows 7 Home Premium Service Pack 1 (64 bits)
# Username : Floateruk - FLOATERUK-PC
# Running from : C:\Users\Floateruk\Downloads\AdwCleaner (1).exe
# Option : Scan
***** [ Services ] *****
***** [ Files / Folders ] *****
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Found : HKCU\Software\APN PIP
Key Found : HKCU\Software\AVG Nation toolbar
Key Found : [x64] HKCU\Software\APN PIP
Key Found : [x64] HKCU\Software\AVG Nation toolbar
Key Found : HKLM\Software\AVG Nation toolbar
Key Found : HKLM\Software\AVG Secure Search
Key Found : HKLM\Software\AVG Security Toolbar
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\au__rasapi32
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\au__rasmancs
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\BingBar_RASMANCS
Key Found : HKLM\Software\PIP
***** [ Browsers ] *****
-\\ Internet Explorer v11.0.9600.17041
-\\ Google Chrome v34.0.1847.131
[ File : C:\Users\Floateruk\AppData\Local\Google\Chrome\User Data\Default\preferences ]
Found [Extension] : booedmolknjekdopkepjjeckmjkdpfgl
Found [Extension] : flpcjncodpafbgdpnkljologafpionhb
AdwCleaner[R0].txt - [1415 octets] - [14/05/2014 20:07:56]
AdwCleaner[R1].txt - [1327 octets] - [14/05/2014 20:15:15]
########## EOF - C:\AdwCleaner\AdwCleaner[R1].txt - [1387 octets] ##########
Followed this and only deleted the greyed out icons as it suggests. Plugged back in USB devices but problem persists.
Dammit. Is it actually the power on the mobo?
14 May 2014   #8
floateruk
Windows 7 64 bit
Thanks for your help by the way. I've been all over the coutry this week, so tonight is the first chance I've had to get back sit and down and try stuff out.
14 May 2014   #9
ICIT2LOL
No probs.
14 May 2014   #10
floateruk
Windows 7 64 bit
So do you think there's anything left to try? Or is it good night USB?
Cheers
intermittent failure of screen saver and power settings.
intermittent failure of screen saver and power off to activate? Hi. My Win 7 Desktop computer, unlike my laptop and other Win 7 computers, has a power and screen saver setup that, at times, never activates? I have checked background processes and can't understand why at times it kicks in and...
Performance & Maintenance
Intermittent Driver Power State Failure event id 41 in Firefox
I have had this 4 time, three within the last week. Dell diagnostics have run with no errors in hardware, ram, or hard drive. No excessive or unusual temperatures noted in I8kfangui. Running updated W7pro Is there anything obvious from my attached zip file? Please let me know what else I...
BSOD Help and Support
Intermittent HP dv7 power problem
HP laptop dv7 almost two years old. Still under hardware waranty. In the past two months I had this problem. I don't happen all the time. Three times to be exact. Laptop will not turn on when I press the power button after shut down. Battery is fully charged. The only way I can turn laptop on...
Hardware & Devices
Intermittent power off
Over the past 2 years my PC has been afflicted with random power off/power on/reboot events. It will go for months without these and then have multiples of the events in a day. (I had 8 of them 3 days ago.) I assume I have a hardware problem, but nothing has been found and I'm grasping at...
BSOD causing intermittent power to monitor on boot
Hi, Firstly, thanks for all the experts here, i have found some very valuable information! OS: Windows 7 Home Premium x64 i7-2600K CPU @ 3.40 Ghz OEM 8Gb RAM Asus P8P67Pro Harware & software build around 6 months old
Intermittent BSOD - BCCode: fe USB Related Error
I am getting an intermittent system lockup sometimes resulting in a BSOD or sometimes a system freeze, e.g. display freezes with no response from the mouse or keyboard. The errors can occur several times a day or it can be a number of days between errors. It is very unpredictable and does not...
