Windows 7: monitor and power save mode
12 May 2014   #1
matts6887
Windows 7 ultimate 64-bit
Sometimes, my monitor will not come out of power save mode even when I hit any keyboard key or hit a mouse button. Its been fine up til now. In order to get it to come out of power save mode; i have to constantly and completely power down then power up; and i dont want to keep doing that as i know that can eventually corrupt windows files. I tried removing the monitor from device manager and let it re detect it; but that apparently did nothing for me. As knowledgable as i am about computers etc; this one has me stumped. What would anyone out there in forum land suggest? my monitor is just a standard run of the mill much older flat panel dell(19 or 20 inch approx.). I also have a wireless keyboard and mouse which also begs the question should i remove the mouse and keyboard from device manager and reinstall them; or go a different route. Thanks Matt
12 May 2014   #2
adamisapple
Windows 7 64 Bit Professional
So you want to go to High Performance mode instead of Power Saver?
{Specialties}
Windows 7 | Windows Vista | Mac OS X | Mac OS 7 | Mac OS 9 | iOS 7 | Vintage Macintosh
monitor and power save mode-button_mos_powerpoint2010.gif monitor and power save mode-button_mos_word2010.gif
12 May 2014   #3
matts6887
no; thats not the issue. The issue is sometimes my monitor will not come out of power saving mode; and as much as i know about computers etc; this one has me stumped.
14 May 2014   #4
adamisapple
meaning it sleeps and wont wake up...?
{Specialties}
monitor and power save mode-button_mos_word2010.gifmonitor and power save mode-button_mos_powerpoint2010.gif
14 May 2014   #5
Mellon Head
It sounds like it's not getting, or not processing, the "wake" signal from the PC. This could be a new fault inside the monitor, or it could be a dodgy cable.
I assume that you've tried another monitor in its place? What happens if you plug in a wired keyboard?
18 May 2014   #6
matts6887
Quote   Quote: Originally Posted by Mellon Head View Post
Well; I dont believe its my keyboard; as the power save mode has worked all along up until just recently. I dont think its the cable either as Ive swapped cables from another dell monitor which was my original one; and that monitor worked just fine with this computer. no sleep problems, etc. As for the keyboard. I dont know where i put my old wired keyboard as my previous computer had a wireless keyboard and mouse as well. I think its the monitor itself as ive tried removing the monitor from device manager and letting windows re detect it and still no change.
18 May 2014   #7
matts6887
Quote   Quote: Originally Posted by emeraldhunter11 View Post
Attachment 317763
{Specialties}
Attachment 317764Attachment 317765
Yes; that is exactly it. Once it goes to sleep; it wont come out of standby(power saving) mode. In this case it sounds like it could be the monitor as i highly doubt its the cables, keyboard, or mouse.
18 May 2014   #8
Mellon Head
Yeah, it sounds like the monitor to me.
18 May 2014   #9
matts6887
yea; thats kinda what i figured. i may have to go back to my old dell monitor which thankfully i didnt sell. Well i guess its safe to say this thread is done so im gonna mark it solved because i know what i need to do.
07 Sep 2015   #10
Bmkreynolds
Mine is doing this and I tried a different monitor and it still happens.
Monitor goes into power save mode while playing games. Forced restart.
As the title states. Just recently my monitor has been going into power save mode while playing certain games. Not all games but some games. Which I am trying to figure out what the problem is before I take it to the shop. If i can somehow fix this issue myself that would be great. Since I really...
General Discussion
PC will not wake up from 'power save' mode
My PC will tend to not wake up when it has been idle for maybe 30mins plus. My screen is set to turn off after 10mins, when I try to wake it up nothing happens basically, but the HDD (SSD) light is normally blinking. My power save options are all set to Windows 7 default apart from: Changed...
BSOD Help and Support
BSOD when waking up from power save mode
Hello everyone, I have a problem with my 6 month old Lenovo B570 laptop. When I try to wake it up from power save mode it often (not every time) gives me a BSOD (driver_irql_less...) and it restarts. I have tried updating, cleaning up the registry with Advanced System Care, looking for new...
Help, permament power save mode.
Yesterday I was trying to figure out what was wrong with my Nvidia Geforce 8800 Gt, so I went to the BIOS, and I accidently set the primary display, or whatever it was called to Onboard. So know my moniter is always on power save mode. My computer is a HP Pavillion, SMD Athlon II X2 Dual-Core,...
General Discussion
Entering Power Save Mode
I installed Windows 7 64-bit Build 7600.16399-0900722-1835. I guess it's the most recent one. I've had it for about a week now, but yesterday, after about 10 minutes, in enters the power save mode and the screen goes back and I'm pretty much stuck. The same crap used to happen with Vista and I'm...
General Discussion
