Windows 7: Help !!! Hard drive 100% Please read
14 May 2014   #1
bradnick
win 7 home 64bit
Ok guys have a tricky one for you, I had a windows 8 laptop with a 500gb Samsung hard drive, the laptop motherboard went down and I put the hard drive in to another laptop to test it, all test including seatools, hd pro and couple of others have verified the drive is 100 % working with no bad sectors or any other problems, I decided I was going to use windows 7 on a Acer laptop so installed with bios set to ACHI mode which i belive is the normal way everything went fine until the windows is finalising the installation, the hard drive locks up and wont go any further, i then formatted again set bios to ide, windows completed and when it went to desktop it again kept locking up, i have googled and googled from forum to forum and cant find any answers, my best guess is the drive has some how been affected by the UEFI from windows 8, its like the drive maybe stuck in hibernation mode or locked, is it possible windows 8 has wrote some code to the drive, i am currently running a 7 hr DBAN 2.2.8 to try and delete any code, guess its worth a shot, i have also tried all the other remedies like disk part, list disk, set as active etc all to no avail.
Any help would be greatly appreciated
Kind Regards and good luck sorting this
14 May 2014   #2
Golden
Microsoft MVP
Windows 7 Ult. x64
Don't bother with DBAN. Have you tried using the CLEAN command from DISKPART during installation?
14 May 2014   #3
bradnick
win 7 home 64bit
Please elaborate
14 May 2014   #4
Golden
Microsoft MVP
Windows 7 Ult. x64
Quote   Quote: Originally Posted by bradnick View Post
Please elaborate
During installation, once the Languages screen opens, do this:
1. Press SHIFT+F10 - a cmd window will open
2. Type diskpart and hit enter
3. Type select disk # and hit enter - # = the disk number you wish to clean/format
4. Type clean and hit enter
Once complete (its quick) close the Window and continue with installtion.
15 May 2014   #5
TVeblen
It could have something to do with SecureBoot as you suspect.
Go into your BIOS Settings and look for the "Secure Boot" setting (usually in the BOOT Tab). If it is in "Windows UEFI Mode" then change that to "Other OS" to disable Secure Boot.
There will also most likely be a CSM or Compatibility Support Module setting. Make sure that is ENABLED.
See if that helps.
My computer and other computers can't read the hard drive.
I REALLY DON'T KNOW WHAT'S GOING ON. My Hard Drive can't be read by the computer but I can eject it. https://33.media.tumblr.com/dc6bd82cd10c60bc39fef803c8943c0d/tumblr_nfrgxlQC1A1rrwbqfo1_1280.png I tried to use the Disk Management method but no luck....
Hardware & Devices
Cannot read old hard drive from usb
I've just installed a new hard drive and installed windows and when I try to connect my old one via a usb enclosure it won't read the main partition. It reads the recovery partition fine but when accessing the main partition it keeps asking me whether I want to format the drive or not and shows up...
Hardware & Devices
Do not read external hard drive
Hi, My laptop does not read my new external hard disk drive using USB connection. The sign "Safely remove hardware and eject media" is there. But the icon of the hard drive doesn't appear in the "Computer". What could be the cause and what should I do? Please help. Cheers, Benny
Hardware & Devices
Computer wont read my hard drive
So i build a newcomputer yesterday. I decided to use my old SATA hard drive from my computer, it has my OS, and other files on it. I get everything put in, but when i start the computer it says "no hard disk is detected". I enter the bios menu, and i notice it recognizes that it is in there,...
Hardware & Devices
Hard drive locked as Read-Only
Ive had this problem once before. I turned my PC on Yesterday, and my WD 500GB Hard drive (Number 3) was not recognised. Then I did a reboot, and the drive showed up again, HOWEVER, The drive has the Read Only flag in DiskPart and using the attrib disk clear readonly commands with the correct...
General Discussion
USB Hard Drive connects but cannot be read
Hi All I have a USB hard drive which when I plug in to either my desktop or laptop is recognised and assigned a drive letter but when I try and click on it or access it in any way either nothing happens or I get the "spinning circle" and have to shut the pc down using its power switch (not a...
Hardware & Devices
