Windows 7: Acer Aspire 5742 no power from dc jack, replaced it, still no power
11 Jun 2014   #1
Huludrock
Windows 7 64 bit, Windows 8 32 bit.....Not too impressed so far
I replaced the DC jack on an Acer today with a new one. When the laptop has the battery in the power LED shows a power source(unfortunately the battery is dead). When I remove the battery and plug in the charger to the new DC jack, no LED. Hitting the power button results in a flash from the power button light and power LED for an instant but no POST or boot. I tried different chargers as I have a few universals laying around so that's not it.....What's the problem?
11 Jun 2014   #2
sml156
Microsoft Windows 7 Ultimate 32-bit 7601
Maybe not enough power on my acer laptop the charger says the output is 19 volts 3.4 amps and it runs fine without the battery installed, When I dont have the battery installed and the charger pluged in there is no indication that the changer is indeed plugged in and also when I turn it on I usually press the button just a bit longer to turn it on
12 Jun 2014   #3
Huludrock
Yep I thought of that too but my universals are adjustable and I matched the voltage with no result. Gotta be mobo I guess.
12 Jun 2014   #4
sml156
The voltage is fine but will it supply enough amp's 3 or 4 amps is quite a lot for a universal charger
12 Jun 2014   #5
Huludrock
They go high enough for amperage too.
Acer Aspire 5742 Series Laptop Over Heating
Hello everyone, I purchased an Acer Aspire 5742 Series Laptop . That is an I3 processor. MY daughter was having problems with it simply turning off. After looking at and running Real Temp and Prime 95, I believed it was simple over heating . It is under warranty so I took it in for...
Performance & Maintenance
Acer Aspire 5742 Bluetooth problems...
So I got an Apple bluetooth keyboard through the post today, and was really excited to start using it. However, when trying to add the device by going Start>Devices and Printers>Add a Device, my computer doesn't detect the keyboard at all. I went into my device manager to see if I could find the...
Hardware & Devices
acer aspire 5830TG no power
Hey, So I have an Acer Aspire 5830TG-6659 that doesnt power up. When the AC adapter is plugged in, none of the lights are lit. Warranty expired so no returns. Yes the AC adapter works, tested with multimeter and with another laptop. I'm thinking either a faulty motherboard, loose connections, or a...
General Discussion
Formatted my acer aspire 5742 , everything I download gets corrupted
i Formatted my acer aspire 5742 with windows 7 home premium yesterday but I cannot seem to install any program . i've tried to install norton and java and the installation always stops and tells me there is an error.What should I do? Any help is appreciated.
General Discussion
Acer Aspire 5742 refuses to boot
Yesterday when I turned on my laptop windows wouldn't start and launched its error recovery. When I launched the startup recovery it gave me a black screen for 5 minutes, then an Acer desktop screen with nothing on it. The loading light will stay lit up for 5 minutes and turn off without the...
General Discussion
USB Ports Stopped working after an Internal Power Jack is replaced.
Hello! Sorry, im new around here! :S Basically, my HP DV6-3065EA running Windows 7 Home Premium (x64) laptop died. I went into a computer shop and asked how much a simple diagnostic test would be to find out how much a repair would be. He quoted me 90. Phew, jog on! That wasn't going to happen!...
Hardware & Devices
