Windows 7: NEED HELP NOT CHARGING W7 Home premium
13 Jun 2014   #1
Jesse0389
32 BIT Windows 7 Home prenium
When I try charging my laptop it says ...% Not charging Please help I'VE REPLACED BATTERY AS WELL
13 Jun 2014   #2
BrendenRea
Windows 7 Home Premium X64
Have you tried clearing the residual power by removing the battery and holding the power button down for thirty seconds or so then replacing the battery?
13 Jun 2014   #3
jgiels
Hi I have a new HP laptop that show connected, not charging. I found this to work.
Disconnect AC
Shutdown
Remove battery
Connect AC
Startup
Open Device Manager
Click the plus (+) sign next to Batteries category, right-click All of the "Microsoft ACPI Compliant Control Method Battery" listings, and select Uninstall In the "Confirm Device Uninstall" dialog box, click OK. (it’s ok if you only have 1 of these listings).
Click the plus (+) sign next to System Devices.
Right-click the “ACPI Fixed Features Button" and select Uninstall. In the "Confirm Device Uninstall" dialog box, click OK.
Shutdown
Disconnect AC
Insert battery
Connect AC
Startup
Hope this can help others.
13 Jun 2014   #4
BrendenRea
Quote   Quote: Originally Posted by jgiels View Post
Disconnect AC
Shutdown
Remove battery
Connect AC
Startup
Open Device Manager
Shutdown
Disconnect AC
Insert battery
Connect AC
Startup
This method may help, but I would recommend my method first. Getting into the devices and reconfiguring them should not be the very first step you take.
BSOD after upgrading from Vista Home Premium to 7 Home Premium
Hi, I've been having BSOD problems(I don't actually see a BSOD the power just goes off) ever since I upgraded from Vista Home Premium to 7 Home Premium. It occasionally happens during start-up or randomly(no specific program or website) at other times. It will also occasionally freeze and then...
BSOD Help and Support
Upgrading from Vista Home Premium to 7 home premium?
Heres my story: Yesterday I was messing around on my brand-new laptop, and I was stupid enough to try a keygen to get Ultimate (I had HP). Surprising. It worked but the copy wasn't genuine obviously. So then I rebooted, pressed F8 at boot. An ran Toshibas recovery to try to get the computer to...
Windows Updates & Activation
Using a licence Home Premium N with a DVD Home Premium (E)
Hello, At first sorry for my bad english. I'm french and i already owns Seven Home Premium N (Full french DVD version with a key). I recently bought Seven Home Premium on Amazon UK (Full non N version, the E uropeen version). This version is entirely in English. As you can see, my english...
Installation & Setup
student download vista home premium to 7 home premium
I have the student download of windows 7 home premium and after downloading and starting installation, it isnt compatible to upgrade from vista home premium. So do I have to burn some sort of dvd for installation, or can i just install from the download i was told to save on my desktop and let it...
Vista Home Premium 32bit to 7 Premium, 62% BSOD
Hello all. I built this system about 1 month ago: GIGABYTE GA-MA790XT-UD4P AM3 DDR3 AMD 790X ATX AMD Motherboard SAPPHIRE Vapor-X Radeon HD 4870 2GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready...
Upgrade Vista Home Premium --> 7 Home Premium --> 7 Pro
I was wondering -- I bought Windows 7 Home Premium Upgrade when it was 1/2 price in July. I can also purchase Windows 7 Professional through the Ultimate Steal here in Canada. I currently have Windows Vista Home Premium on my computer. I really don't want to do a clean install. After I...
