Windows 7: Need help with my power supply
17 Jun 2014   #1
BakaIdiot
Hey guys i been having many problems when i try to play some games they all been crashing lately and everything is pointing to my PSU.
So i need to know if my Psu can hold all my hardware while playing heavy games on High settings, or if theres any software that can help me solving that. (srry for bad english)
My Specs:
OS:Windows 7 Ultimate x64
CPU: Intel Core I5-3330 3.00 ghz
Motherboard: H61M-A/BR
Memory: DDR3 1333mhz 8GB
Graphics Card: GTX 760
Sound: Onboard
Monitor(s) Displays: Samsumg B1930N
Hard Drives: an old 320GB Samsumg
PSU: Thermaltake Smart 550W
Cooling: 3 Cooling fans
Keyboard: A very cheap one
Mouse: Rappo V2
17 Jun 2014   #2
ignatzatsonic
Your graphics card is rated at 170 watts.
I think that Thermaltake is made by Channelwell. I couldn't find a review on it, but I've seen bad reviews for some Thermaltakes.
A 550 watt supply is certainly enough if it's a quality unit. I'd be suspicious of that PSU, but I can't find anything definitive about it.
Edit:
Here's a review
http://hexus.net/tech/reviews/psu/39...0w-psu/?page=3
which has this comment:
Bottom line: a no-nonsense power supply that is capable of powering most mid-range PCs for today and tomorrow.
The Good
Solid performance
Nice cabling
Attractive price
The Bad
Voltage regulation droops at extreme load
Here's another review:
http://www.eteknix.com/thermaltake-s...supply-review/
Pros
3 Year Warranty
Good voltage regulation
Hybrid/Semi-Modular
Affordable
Good modular cables
Relatively quiet
High Efficiency
Cons
Disappointing ripple suppression relative to competition
Poor Crossload performance – voltage droop and high ripple
Could benefit from more PCIe connectors
Read page 10 and make your own conclusions.
22 Jun 2014   #3
ICIT2LOL
Yep they are mostly brands are made by several different companies and Thermaltake not that good in my opinion either and to check the requirements use this
http://extreme.outervision.com/psucalculatorlite.jsp .
To check volts run this HWiNFO, HWiNFO32/64 - Download close the right hand window and click on Sensors scroll down to the motherboard sensor section where it lists the voltages - sorry am on my laptop so cannot give you a pic of what it looks like. The volts should be within +/- 5% of the stated values.
Bought new Power Supply Unit, won't power on. Did I buy the wrong one?
I have a Corsair CX430M PSU with 4 slots to connect in the back. CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com & bought a new Antec BP550 Plus PSU, which has 5 slots to connect to. Antec BP550 Plus ATX12V V2.2 80 PLUS Certified Modular...
PC Custom Builds and Overclocking
Power Supply
Hi My neighbor brought her laptop over its dead (HP Pavilion g series)I think maybe her charging brick is bad, can I try my charging brick (Asus G75) to see if its takes a charge. The numbers are different on the brick than hers will that make things worse ? HP---input 100-240V 1.7A ...
Hardware & Devices
Bad power supply?
So I had put my computer to sleep before work today. I came home and couldn't get it to "wake up." So I powered it down with the button on the front. However, now it will not turn back on. It worked fine yesterday, I played some D3 and surfed the web... Tonight after work nothing. So I laid it down...
Hardware & Devices
Hardware Power Consumption-Picking a new Power Supply
Ok, so it's time again for me to pick a new power supply, however, I'm in need of some help determining the appropriate wattage for my hardware setup. AMD Phenom II X4 955 45nm AM3 GSkill Ripjaw X 16.0 GB Dual-Channel DDR3 @ 668MHz (9-9-9-24) Corsair TX750w (I dont think its the V2) ASUS...
Hardware & Devices
Power Supply
Hello, I am interested in the Nvidia Geforce N470GTX Twin Frozr II. My current card is an Geforce 9600gt. I believe my system currently got a 400W power supply. Do I need to upgrade it? And if so do I need to check anything as in compatibility with my motherboard? Thank you.
Hardware & Devices
power supply?
i changed my video hard to ati 5850 hd 2 months ago since then i get a lot of bsod i format the pc 1 week ago and reinstalled all drivers.. keep having the same problem.. many bsod with diferent message every time. i took it to a workshop and they told me that all is ok,they check...
BSOD Help and Support
