Windows 7: How to test motherboard sound using 2 pin speaker and 7 pin JFP2?
28 Jun 2014   #1
Tsion
7 64bit Home Premium
My mother board is setup as follows:
imgur: the simple image sharer
How can I test the boot sounds using a speaker with a + and - wire?
28 Jun 2014   #2
fireberd
Pins 2 and 8, according to your picture, are the connection for a speaker.
I don't know if that will give you the boot sounds. Depends on what that is setup for on your motherboard.
28 Jun 2014   #3
Brink
64-bit Windows 10 Pro
Hello Tsion,
Do you have a 4-pin motherboard speaker like below to use?
APEVIA CVTCSPK 2" Case speaker cable for computer cases that connects to the motherboard - Newegg.com
How to Test Motherboard
I have two motherboards. Both worked just fine in the past. Recently installed the ASUS M4A79 Deluxe with an AMD Quad-Core (probably a 1st generation AMD - 2nd generation corrected lots of problems as you know). No beeps - just fans and motherboard lights. Classic case of motherboard and/or CPU...
Hardware & Devices
HP laptop no sound from speaker but there is sound through headphone
My wife HP Pavilion DV6175ea laptop running windows 7 ultimate 32 bits was fine with the sound until a month ago. Note that upgraded from vista since the windows 7 launch. From that date till now it as no sound from the speakers but it is ok from the headphones. Tried different audio drivers but...
No sound from speakers but showing sound graph on speaker control
I have an MSI 785GTM-E45 Mother Board. I have no sound coming from the speakers. Tried new speakers and still no sound. If I click on the speaker Icon on the bottom right it shows the speaker graph going up and down as sound is being produced. I tried the head phones and nothing coming from them...
Motherboard might be defective: audio through one speaker?
Hi all, I have a slight problem with my audio and I decided to come here before racing to get an RMA from Newegg. Anyways, the rear audio jack on my new build only feeds sound through the right speaker and my subwoofer, but the left speaker is completely silent. I've already tried a set of...
MotherBoard speaker
Hello ! i have confronted a problem since i install windows7 The MotherBoard Speaker ( Not Sound Card - small speaker on the mother board which can make small sound ) doesn`t work at all it`s very important for me , Thank U
I have hp dv1738od and have upgraded to Windows 7, previously Windows XP. Everything seem to be working ok except, for the sound. Window 7 automatically installed the driver, and said the sound card was working properly. But there was no sound through speaker. I removed the driver and reinstall...
