New PC parts (need help)
  1. Posts : 175
    Windows 8.1 PRO
    Hi everyone, before I ask for some advice on getting new PC parts I know I have posted before about getting a new PC and picking out parts but I don't have the cash so I just need to use what I got :P.
    First I have a AMD Rig its ok specs right now.
    AMD FX4100
    AMD Ghost 7850 GPU
    ASUS Motherboard some crappy one
    and a WD hard drive.
    A really bad bad 500w PSU
    _____________________________________________________
    I would like to get an Intel CPU a i5 maybe but I need a good
    1)Motherboard
    2)CPU
    3)PSU
    4) I am going to pick out a water cooler.
    I am going to get a new hard drive with this and a new windows etc...
    Could anyone sugest a good
    Intel CPU
    also will I be able to use my AMD GPU with the intel cpu?
    thanks for reading,
    Regards,
    Andrew
  2. Posts : 11,424
    Windows 7 Ultimate 64
    Good news first, yes you'll be able to use your Radeon 7850 in a Intel rig.
    What make you think you'll need a new PSU?
  3. Posts : 175
    Windows 8.1 PRO
    I am unsure mate something that can handle the water cool like a H100i or something nothing to massive, also be able to power the CPU and motherboard and GPU ofc, I do not want a 1200 watt one nothing like that, unfortunately money aint on my side :P Thanks for helping me out man !
  4. Posts : 12,012
    Intel CPU
    [/I]
    Not nearly enough info.
    There are dozens of "good" in each category you mention.
    We have NO IDEA about any of the following:
    Budget
    What you will primarily use the PC for
    What dealers you may want to buy from
    When you will buy
    Whether or not you will need a new case, monitor, RAM, or other parts
    And I'm wondering why you've already decided on a water cooler.
  5. Posts : 175
    Windows 8.1 PRO
    I need it for gaming, I got 2 monitors etc....
    I am unsure of the budget right now...
    I don't know about dealers right now.. I need a good one to go to
    I don't think I need a new case, and yea I think yea I will need new RAM too sorry
  6. Posts : 12,012
    What games? At what settings? At what resolution?
    It's kinda pointless to develop a parts list when you have no budget.
    It's also pointless to develop a parts list if you aren't going to build in the next month. Prices change constantly and new and improved products arrive frequently.
    It's up to you to come up with dealers. The standard decent sources would include Newegg, Amazon, and Tiger Direct, but if you live in Timbuktu you may be forced elsewhere. I assume you'll be buying in the UK, so you need input from UK people about sources there.
    If this is your case, it should be ATX compliant. Maybe not the quietest or coolest or sturdiest, but at least usable:
    http://www.newegg.com/Product/Produc...140707214642:s
    If you get a current modern motherboard, you are likely to need DDR3 RAM, probably 1.5 volt.
