Windows 7: Strange heat problem with CPU and MB
23 Jul 2014   #11
Layback Bear
Windows 7 Pro. 64/SP-1
You would have to remove the front cover on the case and take a look. I can't tell you from here.
Your drive bays are blocking most of the front intake.
Like I posted before their isn't much you can do with that case. Clean it and see what the temps are.
23 Jul 2014   #12
harleynut97
Windows 7 home premium 64 bit sp1
Well it's about as clean as I can get it now,
When the computer was NOT experiencing the constant running and heat problems it was running about 42 c now it is down to about 34c .
I appreciate everyones help. For right now I am going to monitor the temps much closer. I'm going to hold off pulling off the cpu cooler for now. This would probably be something I would take in have done at the local computer shop.
Maybe it will serve as a reminder to others to take the time to really check the dust in your computer.
29 Jul 2014   #13
enoctis
Windows 7 Home Premium, x64
EDIT: Didn't notice a second page. Apparently, you've already decided to go this route. Will leave comment for reference.
harley,
That is quite a bit of dust that was built up. At this point, I would not attempt to remove the heatsink. If you feel competent, you can remove the motherboard from the case to clean all around it without having to reapply any thermal paste. The paste only goes between processing units (GPUs/CPUs) and heatsinks. Just be sure to neutralize any electrostatic differences between you and the machine by touching part of the metal frame within before you touch any circuitry.
As for that front fan, I can't see it doing much. There's not enough clearance in the frame between the fan and internal components. The outside grill, however, appears to be sufficient for air intake. That enormous amount of dust buildup that you've removed will make quite a difference alone. Since the case is already open, I would clean all the fans if you haven't. The dust seen on the CPU fan itself in the first picture isn't a significant amount of buildup, and wouldn't much effect the cooling power; much unlike the buildup underneath. However, dense accumulations of dust on a fan will effect the aerodynamics of the blades enough to render the fan useless. It's best to keep them clean.
Were it my system, I would just give it a thorough dusting, which I believe you already have, and put it back together and see how she does.
Dell Inspiron 15R (N5010) Heat Problem..Help Please!
Hello everyone i bought a new laptop two days ago, a Dell Inspiron 15R and i'm happy with its performance main specs: CPU Core i7 Q740 1.73GHz Ram 4GB DDR3 GPU ATI HD Radeon Mobility 5470 1GB (Up to 2737) but i'm worried coz i noticed that it warms once i start it up
Performance & Maintenance
AMD PHENOM II x4 955 BE Stock Heat-sink problem !! :(
Well, Here is my System Spec System Manufacturer/Model Number Self Built Clone PC.... this January OS Windows 7 Ultimate x64 CPU AMD PHENOM II X4 Motherboard MSI p31 Memory 4GB DDR3 1333 Graphics Card Sapphire Radeon 4770HD Sound Card ViaTech HD Built in: with MICROLAB M-111 2.1...
Hardware & Devices
Strange Problem..
Hi everyone, I'm new to this forum and should probably say from the get go that I am not extremely computer savvy. I know my way around, just not in depth stuff. Anyways, I was extracting icons to add custom icons to my HTC Thunderbolt's framework, I extracted a huge folder to my desktop by...
General Discussion
Strange RAM Problem
About twice per week I get a strange message (see picture 1). I traced the origin to the csrss.exe (see picture 2). Ran 10 pases of Memtest 86 the whole night. It did not find anything. Gave my RAM a clean bill of health. Does anybody have any idea what that could be? PS: I am running my...
Hardware & Devices
Windows 7 Over Heat Problem
When i had windows vista on me laptop, it worked fine with no problems, but ever since I installed windows 7 home preuim on Saturday, my laptop has started to over heat constenly within 5 mins of it being on. Any Help?
Software
Strange freezing problem and administrator problem
Hi all, I'm new on the forums. Best Windows 7 forums btw, have helped me a lot. So I'm having two different or same kind of problems. I really need help to solve these! Problem number one:I'm having a strange freezing problem. Sometimes randomly my desktop freezes. I can't right-click any...
BSOD Help and Support
