Windows 7: Replaced battery on laptop, Battery not taking charge.
08 Aug 2014   #1
nitingoa
Windows 7 Ultimate x86
Hi Guys,
I have replaced the battery of my laptop after using it on AC supply for about year after my old battery died.
I get this error message.
"The AC power adapter type cannot be determined
Battery may not charge.
This problem might be solved by:
Connect a Dell 65W AC adapter or higher."
But I am using a 65W Dell Adapter that I got with my laptop.
BTW, I tried the steps for disc AC >> Start>>Uninstall MS ACPI >> Insert battery>> Restart. This process did not yield any favorable results.
Please help!!!
Thanks,
Nitin
08 Aug 2014   #2
Mellon Head
If you take the battery out and just use the adapter, will the laptop boot up without errors?
Laptop Doesn't Charge, Charger or Battery Problem?
Asus u45jc-a1 laptop. My laptop charger cable is in pretty bad shape. You see the wiring broken in the wires on the top part, thus you see the grey wiring inside. When i charge my laptop recently, the charger would go on and off. Such as charging then not charging. I then took a look and the...
Hardware & Devices
Laptop won't charge the battery
Hi guys! i recently purchased an used NC4400 laptop for work.... i chose that model because i have several years working with it and is one of the most rock solid laptops i ever have tried... but this time i think the seller sold me a defective one... the seller sold me this one...
Hardware & Devices
my Laptop battery Acer Aspire One D250 won't charge to 100
Hello, I've only had the Acer Aspire One D250 laptop for less than a year, and the battery already started to fail. For some reason, it never charges up to 100% and after leaving it charging, the white light starts blinking Akku Acer Aspire One D250,Adapter Acer Aspire One D250
Hardware & Devices
Asus laptop battery won't charge
Hi We have an ASUS K52Jr purchased in April last year. At the start of this year the hard drive packed it in while I was trying to download something on ITunes and it would not start up again. We were moving and so didn't get around to taking it in for a couple of months. Anyway, a couple...
Hardware & Devices
Is taking off the laptop battery a good idea?
Hello, I've been quite confused lately...Ever since I bought a new laptop, people kept telling me to take off the laptop battery once in a while and let it run solely on the charger/cable. They say that this could reduce the chances of overheating and could maintain a longer battery life....
Hardware & Devices
