Windows 7: Does Deleting USB HardDrive(Volume)Revert It To Inactive Volume
05 Sep 2014   #1
gary palmer
Have an external USB hard drive caddy with a naked Raptor drive sitting in it which has one partition that is the entire capacity of the Raptor drive...this is an 'active' volume.
1. Can someone tell me if I delete the volume under Computer Management>Disk Management>Delete Volume will this return it to being an 'inactive' volume?
2. Also can you tell me after deletion will I need to initialise the drive in the usual way like when one installs a new drive in a PC?
3. Upon reboot will Windows just offer to initialise it within Disk Management?
I want it to just be a simple, basic, single partition drive just for data backup. In past it was my OS drive which is when it was made an active volume. Using W7/64bit professional.
Thanks...Gary
05 Sep 2014   #2
sfmudd78
Windows 7 Home Premium 64 bit
Use Mini tool Partition Wizard home edition to do what you want with the drive...
05 Sep 2014   #3
gary palmer
Partition - Mark as Inactive
I solved my problem using instructions as described by Brink at:
Thanks Brink and others who helped...Gary
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
Soft Recording volume with Blue Yeti, increasing volume distorts audio
So I have a Blue Yeti, and I'm an online animator/voice actor. Whenever I record audio on my Blue Yeti (OR any other mic) I record about 4-6 inches from the mic, and turn the gain down enough that the audio doesn't peak as I yell or whatever. This is what you're supposed to do if you don't want...
PLEASE HELP- Dynamic Disk Showing Inactive/Volume with E:/ missing
Hello all, I'm a bit of a lurker on this forum as I'm generally not experienced enough to offer advice, but can always rely on this forum to already have already answered any questions I may need to ask. So, as this is my first post in awhile (possibly ever), I wanted to first say thank you for...
General Discussion
Windows 7 7100 - Fluctuating Volume/Low volume
I've had this problem with Windows Vista Ultimate 64, Windows 7 64 7077, and Windows 7 64 7100. Basically, the volume starts out at normal level, then all the sudden it will be real quiet. It stays quiet and no matter what settings I adjust, I cannot get it to play louder again. I would really...
Extremely low volume on headphones but high volume on speakers
y0 I got this other problem i really hate. The most. Please jonathan_king, zigzag reply please. I beg you, i got this problem that i plug in my headphones and its extremely low volume. It use to work fine, but now nope. I tried the jacks on the front, back and my monitor. Please help me.
Deleting old xp volume
Hi, i recently switched from XP to Windows 7, which I installed on disk 1 while xp and debian were on disk 0. Since I want to move completly to Win 7 I want to clean out disk 0 completly. Deleting the Linux partition was no proplem but I don't seem to be able to delete the xp partition. The...
Installation & Setup
