Windows 7: How do I change CD-ROM speed? (Transfer speed is extremely slow)
05 Sep 2014   #1
Ferrum
Windows 7 Professional 64 bit
Hello guys!
So I bought this kick-ass laptop from MSI. It is pretty good. These are the specs (in case they aid in finding a solution to my problem):
Name: MSI WorkStation Series GT60 2OKWS-674US
OS: Windows 7 Professional 64 bit
CPU: 2.7 GHz Intel Core i7-4800MQ
Hard drive: 1 TB 7200 RPM, 128 GB Solid-State Drive
Graphics: NVIDIA Quadro K3100 with 4 GB DDR3 VRAM
Hard disk description: SATA
Optical Storage Device: BD Burner
Cache Memory installed size: 6.0
Problem statement:
I am trying to copy files from a DVD disc (some 3 GB of data) using the CD-ROM on this laptop. The transfer speed is EXTREMELY LOW! It starts with almost 3.5 MB/sec at first, but then after 10 seconds or so, it gets down to 500 KB/sec! The transfer was going to take approximately 6 hours, which is a lot for a laptop with specs like mine.
I tried to copy the same DVD to another laptop, which had much lower specs than my MSI, the approximated time was 10 minutes.
I tried to update CD-ROM but it told me that it was up to date.
Please help me guys!
Best regards,
05 Sep 2014   #2
HarriePateman
Windows 7 Ultimate 64-bit
The Specs don't mean nothing buddy, however the specs of the DVD Driver do...
05 Sep 2014   #3
Ferrum
This is my optical drive specs from msi's website
Optical Drive Tray-in DVD Super Multi/ BluRay Combo / BluRay Writer
05 Sep 2014   #4
OvenMaster
Win7 Pro 32bit; Zorin OS 9 Core (in VM)
I've been fighting with this exact same problem with Windows 7 for over two years, on FOUR different computers - 3 with Win 7 and one with Vista - and we're not alone. This BS started with Vista and Windows 7 Betas. It's a known Windows kernel bug that didn't exist in XP and isn't going to be fixed.
https://answers.microsoft.com/en-us/...1-d97610a2525f
How do I get around this? I put all my thousands of small files into 4GB VeraCrypt containers and burn them to DVD+RW. Transferring large files from DVD to Desktop goes fast enough. Then I launch VeraCrypt and open the file, and dig out the one I want. Large Zip files work well, too.
06 Sep 2014   #5
Ferrum
Do guys think that if I buy an external CD-DRIVE, it will solve the problem?
04 May 2015   #6
Tom Barrister
Windows 7 Home Premium 64
Solve it by leaving 1995 and entering 2015. DVD storage is obsolete. Buy some (USB) flash drives/sticks and backup to those.
04 May 2015   #7
Wandering one
Win7 sp1 Pro 64bit / XP sp2 Pro (games only)
I think that if you look in the tutorials for one called something like "add copy to / move to " the right click context menu and use that instead of the idiotic windows paste thing it will do what you expect. I just tried with a 4gig dvd and windows way would take a looooonnnng time. Brink's way took about 4 1/2 minutes.
Art.
06 May 2015   #8
OvenMaster
Quote   Quote: Originally Posted by Tom Barrister View Post
Nope. USB drives are no faster on the two Win7 and one Vista rigs in my house than DVD+RW.
DVD storage is not obsolete. Discs and burners are still widely available for sale.
HDD Write Speed Extremely Slow
So a couple months ago i started a download for a game on steam but when i was checking it, it would download at 400kb for like 10 secs and say busy writing to disk for a whole minute i have 50DL and 4UP and steam usually downloads at a steady 6Mbps I checked my main HDD write speed and it was...
Hardware & Devices
Extremely Slow WLAN Speed
I finally got my WLAN set up and I'm getting ridiculously slow speed according to LAN Speed Test. When I say ridiculously slow I mean like 10 Mbps slow. The router and all of the wireless cards are 802.11n. I have an excellent signal on both computers. I've tried two different routers and it...
Network & Sharing
Extremely slow boot speed
The speed used to be optimal, but in the past weeks it increased up to 4 minutes which is insane. I disabled most of non microsoft services and startup programs but it does not decrease at all. If you need any further logs/info feel free to ask. Thank you - Tom
Performance & Maintenance
Extremely slow transfer speed from external hard drive
Hi Everyone. I have recently had to format my hard drive and re-install windows. I have also had to replace the motherboard, CPU and power supply. I borrowed a 1.5 TB Freecom firewire external hard drive from a friend to back-up important data before the format, but the transfer speed is...
Hardware & Devices
Extremely SLOW file copying/moving speed sometimes
its taking forever to copy 4.5 gb file... it doesnt take too long normally when im copying to my external hard drive(NESO hitachi xHDD 250GB) :( normally copying a 800MB files takes less than a minute, this time it took >an hour D: Windows 7 64 HP
Extremely slow copying speed over the network
Hi, I have 32 bit Windows 7 enterprise edition installed on DELL Inspiron 1525 with 4 GB RAM. I am facing the issue of extremely slow copying speeds. The copying speed hovers around 4-5 Kbps. Other XP machines are able to do this real fast. I updated from Vista, believing this problem...
Network & Sharing
